Question about Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt Self Propelled quits running also
I have same problem! Self Propelled purchased early June, used maybe 6 times, ran perfectly. Used this past Sunday, no problems. On Mon, it was running maybe 2 mins then died. Now will start after a few pulls, then dies after about 5 secs. Nothing is engaging (blades nor propulsion). Any help appreciated!
Could be the diaphram in the carburater
Posted on Apr 11, 2013
  • rjakers1
    rjakers1 Apr 11, 2013
    Problem Solver:
  • 11 Answers
Clean out the float bowl on the carb sounds like you have gunk in the carb
Posted on Jul 23, 2009
How to fix the self propelled when it keeps quiting on troy mower
check to see if excessive dirt is in the drive wheel dogs clean them this is a problem with there design
May 25, 2014 | Troy Bilt 5.5hp Self Propelled Mower
What can i use to gap a spark plug
the proper tool is a spark plug gap tool , there not too expensive (less than 15 dollars) but in a pinch ive used a credit card edge , its near the perfect thickness for a small engines plug gap
May 21, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy built mower has gas and spark with new plug will not start ,it does not even cough or sound like it is going to start,ran perfect when last ran.
take off the air filter cover and shoot a little gas into the carb.
if it sputters you probably need to have the carb cleaned.
Oct 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Pull mower rope on troy built self propelled mower and it jerks it back out of your hand,hard,,and will not start
This sounds like the engine is out of time.
Usually this happens when the blades hit something hard and shears a small aluminum"key" between the crank shaft and the flywheel.
This is reparable. The little key is less than a buck. A person needs some skills to remove the flywheel to replace the "key".
Wayne
Jul 30, 2010 | Troy Garden
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Jun 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
756 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
