Question about Dell Latitude E6400 Laptop
Dell E6400 onboard NIC cannot get network connection - "A Cable Is Unplugged". The laptop is undocked with CAT5 cable firmly attached.
  • philip mckean May 11, 2010
    do you have the crossover cat 5 cable. this would cause a problem.
    President:
  • 3,278 Answers
I'd suggest updating the NIC driver in Device Manager. But, the message "A Cable is Unplugged" tells me that the NIC port, the CAT5, or the port where is is connected to your modem/router may be faulty. Try moving the cable to a different port on your modem/router, first. Then, try another CAT5. If still a problem, the NIC port is probably faulty. Hope this helps.
Posted on Jul 22, 2009
  • NinaE Jul 23, 2009
    Since those suggestions didn't work, the modem/router could be faulty. Connect your CAT5 cable with another PC or laptop. Let me know.
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Tip
Tips for Media state Media disconnected or Network cable Unplugged
Wired adapter or NIC Local Area connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a physical device or connections
Solutions: 1. Try with a different port on the switch or the router. It could be the fault with the Router/Switch port 2. Try a different Ethernet cable. It could be the fault with the Ethernet cable 3. Try with a different NIC or a different computer. It could be the fault with the NIC
Wireless adapter or NIC
Wireless network connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a some device issue or the wireless settings
Solutions:
1. Try scanning for wireless network and reconnect 2. Remove the profile or preferred networks from its list 3. Check and make sure the SSID and the Security KEY are correct 4. Restart the computer 5. Try with different security types like WEP,WPA or WPA26. Check if the MAC filter on Router/Access point is enabled
on Aug 21, 2010 | Computers & Internet
I can not connect the internet,because my laptop havs a problem with ethernet controller( yellow quwstion)
u can buy a cat5 cable.. or ethernet cable on the nearest computer shop.. and try to look for your nic. or network adapter.. if it doesn't have a problem..
Feb 11, 2010 | Computers & Internet
WHAT DOES A NICHE DRIVER DO FOR A DEK TO PC?
The NIC Driver (Network Interface Card) allows you to use an Etheret connection using a CAT5 cable to connect to a network/internet
Oct 03, 2009 | Dell Dimension 2400 PC Desktop
Due to the power fluctuation my dell laptop 1501 inspron's lan port or network adapter has been burned so whenever i insert network cable in it. it show the message of network cable unplugged
Most laptop lan ports are onboard so replacement would mean replacement of the entire Motherboard. A very costly option. I suggest buying a USB to NIC adapter from your local PC store and just use that for LAN connections.
(side note: get a good brand, cheap USB to NIC/LAN converters sometimes drop connections randomly so spend a few extra $$$ for a good one)
Apr 20, 2009 | Computers & Internet
I am a Support Tech for the Army and really can't find a solution to this problem. When I plug in my Cat5 cable it still says network unplugged only on my M90 computers, all other Dells I have connect find...
Perhaps the "other" Dell's network cards have auto-sense, and you're using a crossover cable... when you shove it into the M90, you get nothing because the wiring of the Patch Cable is not right.
Try a known good "straight through" patch cable.
Mar 11, 2009 | Dell Precision M90 Notebook
My computer (Dell) unknow Network Card
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1: Local Area Connection 1 or 2 or 3
  Network Cable Unplugged, Firewalled
  VIA compatible Fast Ethernet
  in this case u can download VIA network drivers....from internet..
  or
  eg2: Local Area Connection 1 or 2 or 3
  Realtek RTL8139 Family Fast Ethernet NIC
  in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing model     no: RTL8139 through google search engine )
        (OR)
ii) Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select               Network Adapters....
    but this will show wheter ur network adapter or NIC is VIA or Realtek or......but doesnt show the           correct Model NO: of VIA or Realtek....
    so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Dec 25, 2008 | Dell Ethernet Card Network Adapter
Wireless connection works but no plug in connection
The wired nic in your laptop will have a separate ip address than your wireless nic. I suspect you either have the router not set to hand out ip addresses, the info it is handing out is wrong, or you may have a static ip set. Did you ever have the laptop working on the wired nic?
Try disabling the wireless connection, plug up the cat 5 cable, open a dos prompt and type;
ipconfig /all
Notice the information. Now unplug the cable, enable the wireless connection and do the same for the wireless nic. The ip address should be different, but everything else should be the same. Let me know what you find.
Oct 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
Sep 07, 2008 | Dell Inspiron 1150 Notebook
NIC too close to USB port?
Hi Antatg,
Go into your bios and make sure all your USB option are enabled, specially Enable USB for legacy devices, and check to make sure you NIC is enables. Hope that helps!
Good Luck!
Jan 07, 2008 | Dell Dimension 1100 PC Desktop
Dell Latitude E6400 Laptop Logo
566 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
