I have bought a used boat that came with DS400 and when I launched the boat and turned it on. The screen will turn with water temp but nothing else
SOURCE: raymarine gps sounder
This is a common problem if the GPS is hooked up to an electronic heading sensor such as an autopilot. If the heading sensor is not calibrated properly, the boat will appear to be facing the wrong direction.
If you have an autopilot, consult the installation guide and perform the sea trial procedures. That should get your boat lined up properly.
SOURCE: Raymarine Ray 240 usa model
clilk this link
http://www.cwrelectronics.com/wp/pdfs/2006cwrcat.pdf
800-527-3306. call this number
SOURCE: RAYMARINE
press and hold first softkey during power on to "RESET to Factory Defaults" all waypoints will be lost. check the GPS, the actual antenna on arch (mushroom or hockey puck) is the green light flashing every 5 seconds? check at night, it is dim
SOURCE: sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
