Question about GE Washing Machines
GE front loader keeps tearing clothes
2 years old and has been making large tears in clothing about 1-2 times per month for the last year. I noticed that it only tears polyester clothing. Any suggestions on how to prevent this problem?
    Problem Solver:
  • 16 Answers
You are overloading if that is all that it happens .....less clothes more water and set the cycle for delicates...... unless the clothes are coming out stuck around the agitator than thats a different prob....
Posted on Jul 22, 2009
Why does my boot keep tearing, original lasted years, all replacements are months.
had this once before
A wire from an under wire bra found its way in-between the inner and outer drum
every now and again it would find its way to the seal and tear it
then one day the drum started making a loud grinding sound
on further investigation we found the wire
that fixed both problems
Nov 11, 2017 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I rent and the landlord owns the washer. It is a Maytag front load stackable washer. Model # MHWZ400TQ01. I had used it once a week for about 6 months. I is over 5 years old. I noticed a tear in the...
issue him with a written notice of the tear ( also take a photo) so that he cannot blame you for the problem
It is not your fault but normal wear and tear for a machine that old
It sounds like he is trying it on so that you have to fix it
unfortunately it is his machine and repairs are his responsibility regardless of how rough or careful you are
if push comes to shove talk with a lawyer
Mar 29, 2017 | Maytag EPIC MFW9700S Front Load Washer
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
My dryer is ten years old. A few months ago, some of the clothes would come out with rust stains on them. Some of the clothes would get caught in the seams which would cause staining, tearing and...
I would suggest replacing the front drum bearing. Sounds like the gap is now excessive, obviously allowing clothes to get caught up in there. Drum must be removed from the dryer to do this.
Good luck, hope this helps.
Aug 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Clothes smell bad in my GE front loader.  It's one of the first models they came out with - about 3 years old.  Thanks.
Run the unit through a cycle with HOT water and a small box of baking soda plus detergent--no clothes. There are a number of cleaning products on the market that do the same thing (but more expensive). Redo this whenever you notice the smell returning.
Aug 04, 2009 | GE WSXH208A Front Load Washer
GE frontloader door gasket ripped
We had the same problem, I printed off the solution posted by john_in_erie. His repair directions were VERY acurate, however we find a few helpful additions to the repairs - 1st in step #6, the spring loaded wire, is in the front of the gasket under seal (we were looking on top of machine). Also in step #8, you need a short phillips screwdriver or a 7 mm socket with a 1/4" ratchet because of the position of the screw to get around the edge of the tub.
Thank you so much John, we could have not done it without your very accurate installation instructions.
Lori & Mitch Headen
Dec 30, 2008 | GE WSXH208A Front Load Washer
Tearing my clothes, putting holes in towels, etc
Call Frigidaire and keep asking for someone higher up until you get results.
Nov 07, 2017 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Elite HE3T door seal tear
tear may be from pulling something across it with sharp edges..to replace seall not major job front part of seal held in place with spring ..remove and pull boot away from front edge inlet tub slides out of boot opening rear held in place with LARGE screw clamp a little patience is usually all that's needed ..did 2 today
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
250 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
