Question about LG Shine KE970 Cellular Phone
Word prediction turned on but it won't work? LG Shine
Also, should I ask AT&T to send an upgrade so my signal strength will be better. It shows non-service where other AT&T users on various phones have service??! LG Shine
Lg-e410i predictive text
i have lg-e410i . when ever i send sms it always ask allow or deny plz tel me how to fix it.???
Dec 27, 2013 | Cell Phones
How to increase my symbian mobile signal strength ??
I had same prob - after buying an LG Smartphone (SP) to replace my Samsung Mantra flip phone (FP), signal strength was so low that i couldn't use it except as a pc on wifi, so i had the FP reactivated. After ~ 6 mos sprint upgraded the tower and i had the SP reactivated. Now i get 1-4 bars, but if only 1-2 bars voice is sometimes nearly unintelligible... You CAN buy a signal booster and use it in your residence but the cost is hundreds of $. Or you can do research and try to find a SP which has high signal sensitivity. The Samsung Mantra FP has very good signal sensitivity and worked fine even before sprint upgraded the tower... the LG SP has much less inherent signal sensitivity and so needs a stronger signal to function. But there's more to the story...
If you have home WiFi you can switch to T-Mobile and use their WiFi option with your SP to send and receive cell calls via WiFi when your SP WiFi is enabled & connected. I suspect this is what I'll do myself when I get tired of the poor voice quality my sprint LG SP is now delivering. And my guess is that the WiFi option will be offered by all carriers evenually. T-Mobil is just ahead of the curve... IMO.
Dec 07, 2013 | Nokia 5800 XpressMusic Smartphone
I don't have cable. After auto scan for local channels, now 2 local stations are no longer working. I have LG 42LE5400. Do I need to upgrade firmware. Thanks Dj
no you do not need to upgrade the firmware, the channel selection is based on the amount of signal strength it gets, older analog systems would select it as long as there was a slight amount of modulation as for digital it goes by a percentage, if you wish to set these channels then go back under the setup and select manually add channels then you can add any one you whish reguardless of signal strength.
Jun 30, 2011 | LG 42LE5400 42 in. LCD TV
How do i unlock an LG shine, locked to AT&T
You better call AT&T and ask them for the unlock code. I was able to ask them the unlock code last February 13. And they are very nice to assist you.
Sep 13, 2009 | LG Shine CU720 Cellular Phone
LG shine 3G service
Here are the steps:
Enter 277634#*# Scroll down to #5 modem setting and click OK Scroll down to #2 network mode and click OK Click OK again on #1 network mode Scroll down to #2, 2g only, and click OK ***SEE NOTE BELOW*** Press clear until you are out of all menus. Power the phone off, wait 15 sec, power on. ***NOTE*** When changing back to 3g, select dual mode in this step.
Feb 19, 2009 | LG Shine KE970 Cellular Phone
Predictive Text
To get predictive text on or off on the LG Shine go to:
>Menu
>Messaging
>New Message
>Text
>Options
>T9 languages
>T9 on/off
Sep 01, 2008 | LG Shine KE970 Cellular Phone
LG SHINE KE97-Terrible Reception
Call your cell phone provider and they may make a satelite adjustment for the areas you state that are weak.(see if they tell you that your the first one to tell them this about the weak signal)
If they cant help ,get a better phone that will get the signal you need. Please Rate This !!!!!
Jun 11, 2008 | LG Shine KE970 Cellular Phone
Cant send texts
Make Sure You Have A Decent Signal Strength.
Move Around Till You Get A Goood Signal.
Good Luck :)
Regards,
Sophiee.
Mar 05, 2008 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
56 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
