Question about Estro Barista Athena
Barista Athena won't pull shots
I just moved this to my office and within the first couple shots, it's acting as if it's clogged and is only spitting out a little bit until it sounds like it's backing up!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 275 Answers
There is a tiny plastic one-way valve in the brass tube on the pump under the top cover that get calcified and stuck when not in use.
A good pump will fill the tubes in 2 seconds. Lay all your parts slowly and carefully in order during disassembly.
The brass tube with the valve in it unscrews from the angle fitting. Press the little plastic white tab to release rubber motor mount and slide the pump out. Yes it is kind of a technical repair. Unplug unit before starting. I used a toothpick to get the valve out after disassembling the pump and its hoses.
Posted on Oct 11, 2010
I have a starbucks barista athena that has a vapor lock. How do I fix this?
It's easy to break the vaporlock on an Athena.
  1. Power the machine off and let it cool (20-30 minutes is plenty)
  2. Place a mug under the steam wand and open the steam valve all the way. If there's residual pressure, let it release the pressure before proceeding
  3. Power on the machine and wait for a steady stream of water from the steam wand.
  4. Close the steam valve and you should be good to go!
Jan 14, 2011 | Estro Barista Athena
Lights on, motor running, does not do single/double shots
There is a tiny plastic one-way valve in the brass tube on the pump under the top cover that get calcified and stuck when not in use. I used a toothpick to get it out after disassembling the pump and its hoses. Slowly and carefully lay out your parts to reassemble the springs and washers correctly.
Oct 14, 2009 | Estro Barista Athena
I need a manual for the Starbucks Athena Barista - how can I get one?
I believe this is the URL you want:
http://www.starbucks.com/ourcoffees/Barista_Final_011305.pdf
Jan 11, 2009 | Estro Barista Athena
Barista Zia Espresso Machine
file:///Users/Julie/Downloads/Barista_Final_011305.pdf
I had the same problem. The Barista Zia is the same as the Barista Athena on the inside, the only diffrence between the two is the plastic shell on the Zia, and the steaming wand is on the opposite side. This is the instruction manuel for the barista athena, so its basically the same. Thanks! good luck!
Nov 10, 2008 | Starbucks Coffee Makers & Espresso...
Barista athena
I have just had a similar problem. Water no longer moves through the steam wand when I try to prime it. Instead, water shoots through the shot handle (or screen if handle is not in).
One thing I did notice is that the dial for the steam wand unscrewed too far and basically popped out. I screwed it back in and the water did not ever come out of the wand again. I took the top lid plate off and unscrewed the wand dial and removed it. I put it back and noticed that there is a little metal spring switch underneath that I assume turns the wand pump on.
Attached to the dial is a plastic sleeve with a flat side. When the dial is turned, this sleeve should turn the switch on. I noticed though that the sleeve is creeping up the shaft towards the dial head which makes it miss the spring switch.
I don't know what kept the sleeve in place before. Probably a plastic stop that has been worn away from use. There is an allen screw in the sleeve, but tightening it doesn't seem to keep it in place. Perhaps inserting a spring in between the dial and the sleeve would work, but the sleeve cannot be taken off to do this. No other answers right now. My wife is not happy the lattes have dried up.
Aug 13, 2008 | Estro Barista Athena
Estro Barista Athena Tripping the GFI Circuit
is there a diagram for the coffee holder. i took mine apart to clean it and i am not sure how the spring goes in.
Mar 04, 2008 | Estro Barista Athena
Starbucks Estro Barista Athena
Mine is a red O-ring about 2 1/4" diameter, the same as some automotive brake calipers. A well equipped mechanic or parts store like NAPA should have a supply of O-rings with the proper size, best to take your strainer in to test fit.
Feb 16, 2008 | Estro Barista Athena
Estro Barista Athena Logo
156 people viewed this question
Top Estro Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Estro Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
