Question about Euro-Pro NV31 Infinity Vacuum
My vaccum shut off and will not start up.
Can it be fixed?
Does it try? Or is it just totally dead, doesn't even grunt when prodded?
Some will shut off if overheated, and will later start just fine.
Some will shut off if an internal filter gets too clogged and the motor is straining too hard. Open it and clean/ replace any internal filters - often it's just a piece of mesh/sponge in a frame near the motor housing, inside the machine. Remove, rinse, shake off any water, re-insert. Try to start.
If vacuum is the bag style, is there a lever/switch inside that gets pressed when the bag is too full?
For a removable bag, try removing the bag and see if the machine will run for a couple of seconds without the bag present. Of course it might have a sensor and refuse to run if _no_ bag is found... but at least if it did try to run, that would give you a clue.
If it's the kind that has a rug-beater/spinning-brush cleaning head, is there a small (usually red) button possibly labeled "Reset"? What happens if you press that? If no beater head is involved, try looking all over the outside of the machine - and then start opening cover(s) and looking inside for anything like a reset button. Or a fuse. Can't really be more specific. Not a real expert... just spent hours poking around inside my own vacuum for a different problem.
- Inspector Dryfish
Posted on Jul 24, 2009
I can't reset my thermal reset button on my Riccar Brilliance
You may have hair and debris in the endcaps or bearings of your brushroll causing a restriction. The belt sensor thinks you have something stuck in the brushroll so it shuts it off. It's a simple fix, if you can't figure out how to do it take it to your Riccar dealer.
Feb 25, 2016 | Riccar Vacuums
Why does my vac keep shutting down
switch the vaccum on & try wiggling the cord at the plug & see if it stops when you tighten the cord and wriggle it at the plug. This will indicate faulty lead if it shuts dwn when you do this . I suspect problem could be in your pwr lead needs replacing as lead faulty.
to fix replace lead.
Jun 01, 2014 | Nilfisk Vacuums
When vaccum is in use it shuts off after vaccuming for a minute .
Look to see if the main air filter is clean (some can be washed and others have to be replaced) it will if blocked up trip a thermal cutoff to protect the motor in the unit.
Dec 22, 2012 | Electrolux Lux 7000 Bagged Canister Vacuum
Vaccume shuts off after 5 minutes of using. will only start after sitting for hours.
This sounds like an overheat condition. You must have plugged air flow, so rather than cause a fire, the unit shuts down until cooled. Find and remove the blockage << Not always an easy task.
May 21, 2011 | Hoover U5753-900 WindTunnel Bagless...
My vaccum smokes when I turn it on
the belt is probably stuck you need to look and see if its jammed up
Jan 30, 2009 | Kenmore 22312 Bagged Canister Vacuum
A noise coming from the motor when I`m ready to vaccum
if it were m i would take it back and insit on a new one.something new shouldn't have to be fixed thatd why we buy it new
Dec 31, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Vaccum Cleaner
You can download the manual here and it will tell you how to replace your belt. I could tell you, but I won't have diagrams which the manual does. Let me know if you require more assistance.
Dec 10, 2008 | Hoover U5172900 Fold Away Widepath Bagless...
Vaccum Cleaner
you probably broke the belt so check that. if the mains cord is damaged, you should replace it
Sep 18, 2008 | Hoover U8145-900 Savvy Bagless Upright...
NO POWER WHEN I PLUG UP THE VACCUM
I had the same problem when I first bought mine. I let it set for a while and did some online research. I can't remember the site I went to, but it said that this sweeper will shut off when overheated to protect it and will start back up later. I went back and turned mine back on and it was fine.
Jul 27, 2008 | Hoover U5507900 Elite Rewind Bagless...
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Euro-Pro NV31 Infinity Vacuum Logo
522 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
