Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Test why does my machine keep running test sequence when i select any programmes
  • 2 more comments
  • Anonymous Nov 27, 2007
    keeps sayin test
  • Anonymous Feb 11, 2008
    Test displays on panel no matter what programme selection chosen. No programme starts!!!!!!!!!!
  • joannes1969 Nov 15, 2008
    my machine will not select any programmes it jsut says auto test and wil not do anything. my machine is wmd960
  • debfol Jan 01, 2009
    Hotpoint Ultima Super Silent WF840 stuck in Test mode. How do I get out of this? I have switched off from mains, still no joy.
When it is turned on, press the On/Off button and the Start/Cancel button at the same time until the display reads "dOff". This worked for my washing machine after repeatedly displaying "Test" and doing nothing else.
Posted on Mar 27, 2009
  • 146 Answers
Sounds like a problem with you co-processor in you electronic timer. Do you know how to read a wiring diagram? If not you better call someone.
Posted on Dec 18, 2007
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dec 09, 2015 | Electrolux Washing Machines
Aeg 72630 update
Press first left up button and first left down button simultaneously
( during the execution of the washing programme ) for at least 2 seconds: the LED switch off and then display the sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down.
When you read the alarm code,we will be able assume what may be faulty.
Aug 31, 2014 | AEG Washing Machines
The only problem is when program starts it does not take any water and after few minutes it starts indicate error code F1. Hotpoint Washing Machine 8KG WMD960 Ultima 1600
  • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
  • or
      • The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing.
May 17, 2011 | Washing Machines
Code F 35 i cant find my manual
christydubar --
Whirlpool Duet GHW91000 Technical Service Manual does list F35 error code. Try running the diagnostic test below and then write back with condition indication code. -- SWT
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select the DRAIN/SPIN cycle.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The machine keeps showing test. it won't go onto any other programme. it keeps running through the test programme then stops, i then try and put it to wash and it will come up with test again. OK, to help you, I have found you your service and troubleshooting manual. Below is a DIY self help. washer link, this will help you to troubleshoot your issue.
You should try to reset it, but if that doesn't work, you may find you have a main controller board failure.
Jun 06, 2010 | Hotpoint Aquarius WD640 Front Load...
My washing machine Hotpoint wf860 keeps showing Test. please help
The appliance appears to be in shop test mode, to de-activate it follow these steps.
there is 3 differnt variations so here are all 3.
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
These variations could explain why some of us have to make several attempts to clear tESt.
Apr 06, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint washing machine model WF620, keeps reading TEST when you select the programme.
depending on which version you have to
Press the 'Start / Cancel' button until ALL the console LEDs illuminate.
then either
1.Press both 'Start / Cancel' and 'On / Off' buttons together until 'd OFF' appears.
2. Press 'On / Off' and 'Start / Cancel' together with the top left option button (Spin) until 'd oFF' appears.
Mar 14, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Test mode
press start once
then press start again now hold on/off and cancel together for a few secs should no say d/off or something should work now
Aug 22, 2009 | Hotpoint Ultima WF865 Front Load Washer
Keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
230 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
