Question about Konica Minolta Office Equipment & Supplies
Error Code H17
I am getting a wrench on the printer status screen. The error code that appears is H17. Do you have any suggestions on what I can do to resolve the problem?
Thanks!
SOURCE: Printer Fixing Error- Replace Fixing Unit
You need to replace the fixing unit. It costs $120 and replacing it is not a trivial job. You may be better off buying a new all-in-one (not necessarily an HP). I've had good luck (so far) with Brother.
Posted on May 05, 2007
jonniewalker
  • 1031 Answers
SOURCE: Canon MP830 error code 6A00
The problem apparently is related to the purge unit located at the far right side on where the printhead moves back and forth.
there appears to be three common problems that causes the error, which is related to a paper jam error. 1) If its a new printer or even an older one, there are two sponges that collect ink and two plastic wipers located in purge unit may be loose or missing. Check to see if its it there. If not, it may actually be stuck somewhere.
2) there may some paper stuck somewhere around the printhead and or the purge unit or
3) there is a build up of gooey ink on the purge unit.
, I turned off the printer & unplugged it, move the printhead to the left and used long Qtips with Windex to clean up the ink around the purge unit including a little white plastic spring-loaded lever. also dampen the sponges with Windex. If you do this be careful not to dislodge the sponge or wipers. If you do, you can alway stick the pieces back in. After cleaning it, and checking the sponges and wipers are seated correctly, plug the unit back in and hopefully it will work fine. hope this helps.dont forget to rate as fixyaa
thanks and Godbless
Posted on Oct 12, 2008
futureloginn
  • 734 Answers
SOURCE: Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Posted on Nov 27, 2008
  • 4 Answers
SOURCE: Canon BJ-30 Bubble jet printer F-12 error
Hi, According to my BJ-30 & BJC-70 user manual, if F12 is blinking, it is required for this Error code to get in touch with a Canon Service Centre. I had this in the past and being curious I removed the printer chassis from case the and found the problem to be a loose ribbon cable in the connector on the main board from the touch pad circut board . I also had the identical problem with my BJC-70. These printers are very reliable and compact, it seems to be a problem which I think comes about from these printers being so portable. It took me about 15 minutes to fix the problem for which I have made a small modification to hold the cable in place. Having said this, it may not necessarly be your problem but it is a starting point. Canon to my mind have not made another portable printer this good, so if you value it and can find a trustworthy technician get it fixed. If you want further info contact me here.
Regards Roger D
Posted on Jan 15, 2009
SOURCE: Canon PIXMA mp240 All-in-one InkJet Printer. Error code: 2,140,2
I had exactly the same problem (error Code:2,140,2) in Canon PIXMA MP250, and it was solved when I replaced both ink cartridges which were almost empty (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Posted on Jul 27, 2010
What is error code -41
There doesn't appear to be any reliable information about an error 41 code for Canon inkjet machines. In a Brother machine it means a knackered printhead, but Canon has a different code for that. I can only suggest sending a message to Canon's web site/help desk to see if they can shed light on it.
Feb 12, 2015 | Canon Pixma MG5220 InkJet Printer
A RED WRENCH HAS APPEARED
There are hundreds of error codes that will display call for service with a wrench. What is the error code on the screen?
Jun 22, 2014 | Toshiba E-Studio 456 Multifunction Copier
I am having problems with my PS D7360. Error code 0xc18a0306 keeps coming up. I have tried the pineworks suggestion but it did not work. The printer has been sitting for a while.
Found this here it's worth a shot. http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Ink-System-Failure-C6180-error-0xc18a0306/td-p/161866
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
May 28, 2011 | HP Photosmart D7360 All-In-One InkJet...
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
Have a Toshiba E-Studio 350 in the field, and just lost our Toshiba tech. Copier is showing a wrench. Any recommendations?
Wrench appear in the LCD touch screens mean "call for service". It will freeze the copier from operating until the problem is fixed.
There will be an error code appear when you press "CLEAR" and "3" button at the same time. The error code should appear next to the wrench icon you mentioned.
It is recommendable to get an experience tech to solve the problem for you.
Jan 19, 2010 | Toshiba Estudio 200L Copier
Error code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
May 18, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Canon Error Wrench pops up on screen.
drum unit life out or toner unit life out, u try exchange the drum or toner unit to reset the chip
Jan 30, 2007 | Canon imageRUNNER C3200 Color Printer
75 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
