Question about Philips Magnavox 51MP392H Rear Projection Television
Power issue I have a magnavox 51mp392h rear projection tv.When the power button is pressed,it shows power but nothing else.It makes a clicking noise when pressing the power button on or off.Fuses have been replaced.Any help would be greatly appreciated.Thankl you.
  • 5 more comments
  • lee777 Nov 29, 2007
    This is the middle board of my tv.I am getting no power except the tv showing power and a click sound(relay)but,no power .Could my problem be the part with the red wires running to it?A few weeks before this happened,the tv turned itself off and then turned itself back on 2 times.It worked great the night before it stopped working.
  • lee777 Dec 01, 2007
    Ok.I now know that the part described above is the hv generator.This is the part that powers the projectors I think.Would like to know if this could be my problem.I appreciate anyones help.
  • lee777 Dec 09, 2007
    Replaced hv generator.Still no power to crts nor the speakers.Hooked dvd player up to tv and could not get any sound either.Could someone tell me where the flyback transformer is located ?Is it on the board pictured above ?Thank you.
  • gordotv Jun 26, 2008
    hi everybory i have the same problem and i check the board down of the flyback and i find 2 mosfet fqpf10n20 bad i need to find that pcboard number 3122 133 32721 thanks
  • foxstyles Jul 01, 2008
    My phillips projector tv turns itself off and makes funny noises. What is the probles? I have unplugged the tv for 24hrs several times and it still doesn't work!!
  • glenn792 Jul 02, 2008
    my problem is the tv comes on for 15 min then turns off, I REPLACE THE LAMP 3 WEEKS AGO.COULD IT BE A BAD LAMP..
  • lee777 Sep 01, 2008
    Would i need to replace the power board if it is going into high voltage shutdown?
  • Philips Master
  • 3,459 Answers sell kits to fix this common problem.
Hope this helps,
Posted on Jun 24, 2008
    Problem Solver:
  • 3 Answers
Yes, I believed it in the picture that you are showing with the three red wired are coming from . should have about 9 to11 pins in a rounded circuial on the board
Posted on Dec 11, 2007
  • john bidd Dec 11, 2007
    From your orgin post it migh be going into High Voltage shut down
Magnavox 51mp392h rear projection t.v's power button will blink continuous and there is a low chirping noise. T.V. does not turn on.
The chirping may be the key...When this is commonly the case its a convergence short. See more details on the site - Look for a chirping repair kit for your model. Its a common issue
Mar 02, 2013 | Philips Magnavox 51MP392H Rear Projection...
Philips magnavox,9p5040c102 tv has power but no pic or sound, what is wrong, worked fine yesterday
I have same problem with mine, the power button turns red (as usual) but no picture. When i turned mine on last night it made a crackle noise and thats how it all started. I can even hear the normal sounds it makes as if it were turning on, but still no picture. Its a great tv I would hate to throw away. I want to fix it myself any help would be appreciated!
Aug 21, 2011 | Philips Magnavox 51MP392H Rear Projection...
My daughter kept pushing the on/off button on the tv. Now when I push the on button I don't see anything on the screen and I head a chirping noise. Nothing else happens. Help? Is this repairable or do I...
good day. maybe the power supply of your tv damage or fuse worn out. causing the on and off of your daughter. but it is repairable. you just need a qualified technician to fix your problem.
Jun 21, 2010 | Philips Magnavox 51MP392H Rear Projection...
Philips rear projection tv-wont turn on
Sounds like your Convergence chips failed, were your red/blue/green colors slowly seperating or was the picture starting to curve on the top or bottom or both? if so see below general post.
Also what model # is your TV and what size?
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
Where I got all my parts that worked:
Suburban Electronics
Manual Library you should find all you need here:
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with.
Nov 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv wont turn on
your tv is in shutdown mode replacing the power suply module may corect this problem
Oct 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv wont power up makes a noise but no picture
Replace your STKS big black ics 392-020 go to 040s if 119s 150s go to 180s.
Oct 13, 2008 | Philips Magnavox 51MP392H Rear Projection...
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Mute and C on the screen
The TV is in factory or demo mode - turn tv off and unplug it from wall outlet for 30 seconds - turn tv back on after 30 seconds and see if problem goes away. If not, press the (volume -) and (channel -) buttons repeatedly for about 10 seconds to see if "C" will go away. If this fails call 1-888-PHILIPS for further assistance (they do Magnavox also).
May 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
51MP392H rear projection - flashing on/off button
Power light but no audio/video is fairly common problem. Goto to see if they have a repair kit for your model.
Oct 11, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
181 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
