Hello Candy Johnson,
Without your actual MAKE & MODEL numbers...
It comes close to WILD-EYED-Speculation...
But my GUESS is that your batteries have seriously corroded.
It is possible you could recover your remote assuming you could gently tap around the mated surfaces ...
(corrosion can get into in-reachable areas... and for the cost of a replacement... chancing getting that caustic corrosive on your skin simply is not JUSTIFIED.
My suggestion would be to look over the remote
Get the number DIRECTLY look on AMAZON and EBAY for your EXACT REPLACEMENT..
The last BRAND NEW SAMSUNG AA59-00600A
was less than $7... delivered.
Try it... Way safer than playing with leaking BATTERIES
Samsung AA59 00600A AA5900600A replace remote UN32EH4000 UN46EH6000F...
Carnac the Magnificent
Setting up the remote control
WARNING: Keep the remote control battery away from children. It may cause a fire or
chemical burn if mishandled. Do not recharge, disassemble, heat above 100°C (212°F), or
incinerate. Dispose of used battery promptly. Replace only with a battery of the correct type
and model number.
Your remote control may be one of two types. Each is identified by the way
the battery compartment unlocks to install or replace the battery.
1. Place the remote control face down on a flat surface.
2. If your remote has a slot on the back, follow step A. Otherwise, follow step B:
A. Insert the tip of a ballpoint pen into the slot. Push to the side as shown and hold. Slide
the battery compartment open with your finger.
B. Using your finger, push the tab lock to the side as shown and hold. Slide the battery
compartment open.
Setting Up
See operating
instructions for types of
battery to be used
Note: Use only a Duracell, Eveready, Maxell, or Toshiba CR2032 or DL2032 lithium battery
(available at electronics stores). If you have difficulty finding a replacement battery, contact
Bose® Product Support (see phone numbers on the inside back cover).
3. Keeping the remote control face down, insert the new battery into the compartment with
the + symbol facing up.
4. Gently slide the battery compartment closed. It locks automatically.
5. Use the supplied mounting strip if you want to attach the remote to a surface in your
listening room. Peel off the protective backing to stick one piece to the back of the remote
and the other to the selected surface.
