Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquariua WF740 - new bearings?
Hi. My 3.5 year old machine is starting to make a grinding mechanical noise when it spins. It's not hugely loud but definitely something is going wrong and want to find out if I can fix it. Have read some stuff about bearings. Could this be it and if so, how tricky are they to replace and is it worth it?? Thanks loads in advance for any help.
  • jamesoconnor Jul 22, 2009
    Thanks. How do i fix it??
    Problem Solver:
  • 16 Answers
Its the bearing .....
Posted on Jul 22, 2009
Is it possible to change the bearings on this model?
sealed units are separate to the tub and drum
I would first remove everything down to the outside drum as the noise could be from an obstruction ( coin/s bra wire, metal objects etc)
At 3 years I would not expect bearing trouble in a sealed unit so explore all other avenues of the noise first
bearings will be noisy at all cycles and not specifically at high speed spin
before you touch it -check the warranty period and if inside that period call the technician
Feb 10, 2016 | Hotpoint Washing Machines
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
FAULTY WASHING MACHINE
is it a GE or Hotpoint? if so it is the main bearing. the center seal might have leaked water on the bearing.  if you look inside the washer you will see a ring of rust splatter inside the case of the washer. if this is the case than you have to change the transmission or buy a new machine.
transmissions are $200+
Jun 27, 2008 | Indesit Washing Machines
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
How to replace a Hotpoint Aquarius+ WF740 drum bearing?
I had the same problem and it turned out to be the ballast securing bolts had sheared off and the back of the drum had to be replaced
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
479 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
