Question about Whirlpool Duet GHW9150P Front Load Washer
WASHER CUTS OFF IMMEDIATELY AFTER BEGINNING TO IMPUT WATER, THEN SHOWS "FAULT 11" DON'T HAVE SER. MANUEL TO DETERMINE WHAT FAULT 11 IS, CAN YOU HELP? THANKS
    Problem Solver:
  • 16 Answers
F11 is a motor control board or if u are lucky a loose connection at the upper control board ....motor control is down at bottom main control is at the top back of washer
Posted on Jul 22, 2009
Drain pump continuously running on Samsung Model WF448AAP/XAA
do pull the plug out first
not funny dancing with the machine
have you checked the pressure pipe for any cuts
look near the pressure switch area first
Feb 05, 2014 | Samsung Washing Machines
20litre fsi, Epc light comes on when coolant temp gets to 90, then vehicle cuts out, fault code shows fuel pressure regulation control lower limit exceeded P1020, wher might the fault lie?
car systems r so complicated-dont go buyin new parts till u hookit to a tech ll that runs a data stream--hav u done regular tuneups and fuel filter change
May 19, 2011 | 2002 Audi A4
Washer at the beginning shows a F1 and takes 5 tries until it works.
YOU ARE HAVING A WATER FILL PROBLEM CHECK THE WATER VALVE AND WATER PRESSURE IF PRESSURE IS GOOD THEN THE WATER VALVES BAD IN MOST CASES.
Dec 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
No spinning action on my MW511 Fisher and Paykell Wash Machine. Drains water ok. Then shows small beginning of back/ forth agitation - but not progressing to full spin mode. Warning lights showing...
Hi just read your posting.Now with the error code you have shown it tells me you have an out of balance fault.To find out if the fault is with the out of balance switch or the motor controller you will need an electrical test meter. the reason for this is to test the switch for conductivity,not to test for power or anything dangerous.Have you or can you borrow an electrical test meter to test the switch?please reply and I can guide you throe the repair of this fault.
Jun 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
My water heater cuts of after 30 seconds and shows C2, 11 code
sounds like your gas lines are too small or not enough pressure... or you may have to clean the rods
Jan 13, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
How to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Maytag commerical washer model MAT10PSAAW COIN MACHINE . THE COIN VALUE IS 1.00 IT SHOWS 2.45 THE FAULT CDE IS dA5 how to reset to working status
I have been answering other peoples problems on this site I am a electrician . I still haven't fix my freind washer yet because the Code reads dA5 If I new what this code ment I could fix rhe machine . The machine is a maytag model number MAT10PSAAW SER AO592928MF
THE MACHINE IS A COIN WASHER 1.00 COIN . IT SHOWS 2.45 if I could get it back to read 1.00 ,I think it would work . Again the code is dA5. I have been searching the net . knowone yet with a clue .
Nov 26, 2008 | Maytag Washing Machines
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Whirlpool Duet GHW9150P Front Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
