Question about Brother MFC 6800 All-In-One Laser Printer
Brother MFC6800 not printing
My Brother printer just stopped printing. The paper comes out blank. It will print from the fax, but not a document from my iMac intel computer. Had been working fine, then just stopped.
  • SteveChin Mar 21, 2008
    I got an error to change the toner and the drum. When they were installed the pages come out blank: both from printing and copying.
    Also the machine tries to load two pages per copy. I checked the paper size and we also put in the old drum and toner cartridge.
    Still puts out blank pages even with the old drum and cartrdge.
    Any ideas. We have installed and reinsatlled the drum and toner multiple times
  • 4 Answers
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Posted on Nov 20, 2007
After fixing a paper jam my printer started printing blank pages... What do I do?
Come on, none of these solutions are helpful. She obviously got the paper jam fixed and didn't need advice about that. It prints a blank page not Black doesn't print right. And a damned spam post linking a commercial site. I'm having the same problem and this is no help.
Mar 26, 2013 | Brother MFC-J435W Network-Ready Wireless...
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Cancel printing/receiving long, unwanted fax?
You should show an Icon in the task bar when printing,right click it.Then click cancel print job.You can also get there by start menu,then click printers and faxes.Then click your printer and cancel print.
Note:you can always do a print preview by clicking the little arrow(in explorer)next to the printer Icon.Then pick what pages you want to print,click apply,then print.Hope this helps?
Dec 19, 2009 | Brother MFC-7220 All-In-One Laser Printer
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax printing out blank paper
New print head, might be cheaper to replace machine
May 21, 2009 | Brother Fax-1360 Plain Paper Inkjet Fax
Printer only printing a blank page
Try to reset the printer and print the demo page
May 05, 2009 | Brother MFC 490cw Color Inkjet...
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Print and copy comes out blank paper
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
FAX will not print.
I have the same problem. Found this solution on the Brother site:
If the faxes you receive and the copies you make print half blank pages
please follow the steps listed below:
1. Unplug the power cord
2. Lift the top cover up.
3. Next, lift the two purple release levers located on each side of the
metal plate. The print head will pop up.
4. Remove the ribbon cartridge from the unit.
5. Lift the plastic paper cover (located behind the black rubber
6. Carefully remove any paper that is jammed by pulling in an upward
7. Push the paper cover down (located behind the black rubber roller).
8. Place the ribbon cartridge back in the unit with the ribbed triangle
on the plastic casing furthest away from you. Make sure the cartridge
gears rest in the white gear holders.
9. Gently push down the print head until it clicks into place.
10. Close the top cover securely.
11. Plug the power cord back in.
Test by making a copy.
1. Place a document (with text on both sides) in the ADF (automatic
document feeder).
2. Adjust the paper guides on the sides of the ADF to fit the width of
the document.
3. Press the COPY key.
If the problem continues and your machine is within warranty, you can
locate a Brother Authorized Service Center (ASC) in your area using one
of the following:
Click on: and then click on the "Service
Center Locator" option located on the left side of the page or for
automated assistance by telephone, dial 1-800-284-4357 access our fax
back system. This system can provide you a printed list via facsimile or
verbal listings of a Brother ASC in your area. You may also contact Brother Customer Service at 1-800-284-4329 Monday through
Friday, 9:00am- 7:00pm EST, excluding holidays. If you are out of
warranty, you need to contact a Brother Authorized Service Center using
the information listed above.
Nov 16, 2007 | Brother IntelliFAX 1250M Fax
Brother MFC 6800 All-In-One Laser Printer Logo
209 people viewed this question
James Cagle
James Cagle
Jim Keysor
