Brother CS-80 Logo
Cat Trainor Posted on Feb 12, 2017
Assembly a new bobbin winder and the spring came off need to know how to put it back on Brother CS-80
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on Jan 06, 2009
SOURCE: Needle thread getting caught in bobbin are on Brother Cs-100
I don't know if this is any help, but I would suggest taking it in to a repair store. So here is a way to find places that repair brothers machines. The place near me has done a great job both times I've gone in. Also they usually don't charge for labor, just parts. If they charge for labor it probably won't be much.
http://www.brother-usa.com/service/
Anonymous
  • 30 Answers
  • Posted on Aug 22, 2009
SOURCE: mass bunching of thread in the bobbin compartment
it had nothing to do with the shuttle, it is the upper thread is not in the tensioner. lift the presser foot up and thread the machine even if you have to hold the thread on the top and pull on the bottom to make it go in the tensioner it will help, if a machine loops on the bottom it is the upper tension if it loops on the top it is the lower tension
Anonymous
  • 16 Answers
  • Posted on Oct 01, 2010
SOURCE: Help me !!!!! Got a brother XL2230, bobbin winder broken
Hi, I have the same problem, use a car 'o' ring that should fix it, should cost about
ju222dy
Judy Tew
  • 8 Answers
  • Posted on Aug 09, 2012
SOURCE: Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
rodgethebike
Roger Saunders
  • 26 Answers
  • Posted on Mar 25, 2014
SOURCE: Brother CS80 ..... bobbin winder
The rubber ring on the bottom end of the bobbin winder shaft has degraded, gone all sticky and is probably somewhere inside the casing. You need a new rubber ring fitted. If you are not handy take the machine to a repairer. There are more details elsewhere on Fixya about doing this.
2answers
How to Remove front cover of Brother CS-80 sewing machine
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Getting the cover off my brother cs 80. all screws have been removed and the cover comes off partially. I seems to be stuck at the turn wheel, like something is holding it fixed.
I had the same problem when opening my machine. The problem is a screw underneath the bobbin winder area. Pull the bobbin base off and then gently pull up the bobbin winder assembly from under the front cover. You will see a screw in the corner to remove so that you can complete the task. I had to purchase a service manual and then I had great success with replacing the bobbin winder "tire" (Bobbin Winder Tire, Babylock, Brother #X55238051 at sewingpartsonline.com - $3.99!!)
My bobbin winder works like a charm now. Sewing Parts Online Search
Bobbin winder
then there is something wrong with the bobbin winder & it needs to be repaired
Bobbin winder stop before befor fully wound
Is the bobbin close to full in the middle but not that full above and below? You may need to watch the bobbin wind and give the thread a nudge so that it fills right across the bobbin core to avoid this happening. Most bobbin winders will click off before the bobbin is completely full as you don't want any thread actually touching the bobbin case when it is in position, just fill to about 80% for good tension and stitching.
2helpful
2answers
Brother CS80 ..... bobbin winder not working. power not being transfered to the shaft that turns the bobbin. how can i fix it?
check the power cord to see if it plugged in to the machine correctly
& if it is then something could be loose or broken inside, it needs to be serviced
The bobbin will tread at all! no fabric is caught-up. motor run but not threading.
If you need a manual to see if everything is set up as it should be for winding a bobbin or any other feature of the machine, you can view or download here - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=CS80
If you are still have a problem, the bobbin winder may be broken.
You can have it repaired or purchase an auxiliary bobbin winder for a lot less money - SideWinder Bobbin Winder where sewing notions are sold.
Brother CS-80 Sewing Machine Bobbin Rewind
For $30 you can buy a standalone bobbin winder (Sidewinder) at JoAnn's Fabrics or Amazon. It's a great little accessory (battery or electrical) because it saves wear and tear on your machine but also allows you to wind multiple bobbins without having to unthread the machine.
2answers
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Cannot wind the bobbin
5helpful
4answers
Can't wind the bobbin
Bobbin will not lock on bobbin spindle, what can I do?
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
