Home | DVD Players | Mintek DVD player
DVD Players
Problem for DVD Players
Generic problem for all DVD Players
Mintek DVD player
By JETJOB27 on Nov 20, 2007
I have a mintek model MDP-1030 that the screen shows no disc when you load a disc in it?
Same Problem
May 25, 2009
-   i put a disc and says loading
then
no disc appears-   Guest
Mar 29, 2009
-   I have the same problem. If you remove the 6 screws and load the CD or DVD see if the motor turns. If it does try cleaning the read head. It is located under the center spindle of the disc. I would use a q-tip and rubbing alchohol. If the motot does not spin it is probably the power supply or the motor in which case the price for these would outway repair.-   Guest
Dec 18, 2008
-   The player keeps showing the "loading" icon and never loads the movie or says there is "no disk" and there is a DVD inserted. Have tried several DVDs.
-   nmorrison00
Best Solution
posted on Nov 20, 2007
Helpful)
mikemilw
Rank: Wiz
Rating: 83%, 426 votes
Clean the DVD or CD. Also try to clean the lens of the unit. You can either use a DVD cleaner or if you are very handy and careful you can open up the unit and get access to the lens. Use a tiny bit of windex or similar cleaner on a q-tip to wipe the lens and the other dry end to wipe off any excess reside. Again you need to be very careful about cleaning your lens this way.
If these tips don't help, your spindle motor on your unit is bad and you might as well just junk it (spindle motors are probably about as much as you paid for the unit).
Mike
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for DVD Players
Questions and Unsolved Problems for DVD Players
Answer
what sort of scart lead for product dvp3360
Answer
Which is the Best and Lower Price DVD player
Answer
how do i transfer copy protected vhs to dvd on lg rc797t, i'm able record hbo to vhs but not to dvd.... (More)
Answer
Describe your zenith dvd player does not start Problem- when we put a dvd in, it won't start... (More)
Answer
what is the remote mod# sony rdr-gk300 dvd recorder pegbread@yahoo.ca
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For DVD Players:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
