Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Smelly Ice and water leaking into top shelf
My kenmore 18.5 cuft top freezer is making smelly ice. I just replaced the in-line filter, and the ice is still horrible. I am also getting water leaking from the top of the fridge (near the light) onto the shelves in the fridge. Any ideas? Please help.
  • mdbarone Jul 22, 2009
    Not on well water. I live in Los Angeles County, and my tap water is fine. I have an in-line filter (home depot purchase) coming off of my cold water line under the sink to the ice maker line. I used to run the ice maker without a filter, and it started to get smelly so I put the in line filter in. It worked fine for months after that, then it started to smell again. I figured it was just a routine filter change. But once I replaced the filter it still smells...quite bad actually.
  • charles farrow May 11, 2010
    are you on well water
    Problem Solver:
  • 15 Answers
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Posted on Jul 24, 2009
Water keeps drain into the refridgerator but it still freezes and still keeps food cold in the ice box I just replaced the filter about a month ago.I also have been keeping a towel in there to soak up the...
Take out the back panel inside your freezer and locate the drip line in there, it should be some where under the coils, check if its blocked up with ice, if it is you need to unclog it. there should also be a wire that runs into that drip line (it helps defrost that line) you might need to replace that wire.
Feb 20, 2013 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 79577543600 Fishy Water Dispenser
HI THERE.well this is a tricky one.4 filters is alot of filters.should have cleared it.all i can sugest is to check water before filter.could it be that the problem is before the filter.try.good luck.ali
Aug 21, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore side by side frigerator and my ice maker is not producing any ice. I have tried turning on and off with the wire switch but that dis not work.
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
When the Ice Maker Leaks
1. Refer to your user manual to determine where your fill volume adjustment dial, is and turn it down. One-half to one full turn usually is approximately equal to 20 to 40 cc, and the correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
2. See if there are icicles hanging from the fill spout and/or on the ice maker's sides. If there are, this means your water inlet valve is leaking and will need replacing. Refer to your user manual for a part number, or call a technician.
3. Check to see if the ejector seal is cracked. If it is, replace it. Refer to your user manual for a part number, or call a technician.
When the Ice Smells
1. Replace water filters every 6 months to avoid musty odors from getting into your ice. If you don't replace the filters, they become clogged with the chemicals they have been removing from the water. In addition to smelly ice, you may see a drop in water pressure if you have a water dispenser, and possibly a decrease in ice cube size.
2 .Remove the cap from the new filter.
3. Place the cartridge inside the holder, and twist to the right.
When the Ice Maker Produces Hollow Ice
1. Replace the fill and shut-off valve for problems with both parts. Hollow ice cubes usually indicate a low water problem. This is generally the result of an excess buildup of calcium and other deposits.
2. Replace the self-piercing shut-off valve with a drill-type shut-off valve.
3. Drill a 1/4-inch hole into the pipe and install the shut-off valve the same way you would have installed the self-piercing valve
Hope this tips would help.
Have a nice day : )
Jul 07, 2011 | Kenmore Refrigerators
Water and Ice have tasted like **** since we got the refrigerator (about 1 year ago) I believe the soultion is bypass the storage tank, but I can't find it..
When the Ice Smells
2. Remove the cap from the new filter.
When the ice smells...water & ice have tasted like ***** also.
Good day : )
Jun 21, 2011 | Refrigerators
The refrigerator and freezer works fine. The problem is it is leaking water from somewhere under the frige. The condensor was cleaned out this last week and did have a lot of dust. Couldn't find any...
1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
1 Refer to your user manual to determine where your fill volume adjustment dial, is and turn it down. One-half to one full turn usually is approximately equal to 20 to 40 cc, and the correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
2 See if there are icicles hanging from the fill spout and/or on the ice maker's sides. If there are, this means your water inlet valve is leaking and will need replacing. Refer to your user manual for a part number, or call a technician.
3 Check to see if the ejector seal is cracked. If it is, replace it. Refer to your user manual for a part number, or call a technician.
When the Ice Smells
1 Replace water filters every 6 months to avoid musty odors from getting into your ice. If you don't replace the filters, they become clogged with the chemicals they have been removing from the water. In addition to smelly ice, you may see a drop in water pressure if you have a water dispenser, and possibly a decrease in ice cube size.
2 Remove the cap from the new filter.
3 Place the cartridge inside the holder, and twist to the right.
1 Replace the fill and shut-off valve for problems with both parts. Hollow ice cubes usually indicate a low water problem. This is generally the result of an excess buildup of calcium and other deposits.
2 Replace the self-piercing shut-off valve with a drill-type shut-off valve.
3 Drill a 1/4-inch hole into the pipe and install the shut-off valve the same way you would have installed the self-piercing valve
Some are tips for your future reference.
Have a nice day!
Jun 01, 2011 | Refrigerators
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice tastes funny all of a sudden.
you need to throw out the ice. ice gets stale after a couple of weeks , so toss the old ice. also is there something like garlic or another food that has a strong oder uncovered in your refrigerator section? air flow covers all of the unit, both refrigerator and freezer sections. if your refrigerator is not smelly , put an open box of arm hammer baking soda on a shelf in both sections of the refrigerater. if water and ice still taste funny shut off water supply and check the filter at the rear in the lower part of the unit. take off connecter and visibly check the strainer in the water valve,clean it out by removing it and rinsing it under the sink faucet. make sure that water from other faucets taste ok . the only thing left is to flush out the water tank by filling up glasses of water until the water gets room temperature . that's about all you can do short of replacing the water line leading to the refrigerator, although i have never had to do that before. good luck
Jan 23, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
ICE CUBE MAKER SMELLY ICE CUBES
your model will have a filter for it. it is located usually on the fridge side torwarss the top back of the fridge. it sounds like you need to replace the filter. it needs to be replaced every 4 monthes or so to keep the water clean. also you may put some water in a cup from the tap/faucet and make sure it is not the water it's self. if it is you may want to think about also having a water filtration system installed in your home.
Jan 07, 2009 | Refrigerators
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
382 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
