Question about HP Photosmart C6180 All-In-One InkJet Printer
Repeatable Error on Scan/Fax/Copy
I get the same Repeatable Error on Scan/Fax/Copy -- HP says it's the lamp gone bad, but they will not tell me a part number to replace it, nor can I order it from them. Grr
    Scholar:
  • 122 Answers
I found the all-in_one for sale on Amazon, new for 167.00. The low end units are cheaper to replace then fix. If you found the part the cost plus shipping and installation would be more then it is worth. My rule of thumb is that when the repair cost is 50% or more of the replacement cost I replace it. Good Luck
Posted on Jul 22, 2009
My mfp m1132 is showing error E8 and cant copy/scan. what do I do?
Juliet. Most likely the scanner lamp, or scanner control unit assembly is defective. If you're technically savvy, you could remove the scan glass and lube the shaft that the scan lamp assy slides on. Sometimes that will fix it. Otherwise, the whole top scan unit will need replacing. That could cost over $300 for the replacement.
Oct 07, 2015 | HP LaserJet Office Equipment & Supplies
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Have an hp 1536 fax and copy work but won't scan to computer. error message scanner is already in use but noone is using it???
Try deleting all the HP fax, scan, copy, etc., software and reinstall using disc that came with it. Other option is check HP's site and see if there is an updated install package.
Apr 24, 2014 | Office Equipment & Supplies
My HP 7110 Officejet says ''scanner failure.'' It will not let me fax or copy. How do I fix this?
If you can remove the glass, you need to clean the lamp and mirrors in the scan assembly, this error happens after the lamp ages and dust gathers on the scan mirrors. It's very expensive if you can even find a new scan assembly.
Jun 30, 2009 | HP Officejet 6310 All-In-One InkJet...
Black page printwhen I try to copy or fax from my hp 6110 printer
The printer isn't shot, but the scan assembly is, it sounds like either the scan lamp is dead or the sensors in the scan assy. You should also be getting a scanner error. I would try the reset, powering up with either the #3 or #6 buttons pushed, and see if a reset helps.
Jun 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Will not receive fax Will not send fax Will not copy Has error Message 76 on monitor
Machine error 76 is a bad fuser lamp.Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
May 13, 2009 | Brother IntelliFAX 2800 Laser Fax
When I copy, send a fax, or scan it turns out HP 6310 all in one
this is a hardware issue..connect the printer to the wall outlet..and then try to make a copy..if its still the same then machine should be replaced..reason is scanner blub is gone bad..
Mar 09, 2009 | HP Officejet 6310 All-In-One InkJet...
For my hp color laserjet 2840
You have a bad scanner assembly. Very expensive to get fixed
Mar 02, 2009 | Office Equipment & Supplies
HP 1020 fax
From manual: Insert document; press Scan & Fax button; dial number; press Start/Copy.  All pages will be scanned, number will be dialed, and scan will be transmitted.  If Memory Full displays, repeat procedure without using Scan & Fax button.
Jul 15, 2008 | HP 1020 Plain Paper Thermal transfer Fax
HP Photosmart C6180 All-In-One InkJet Printer Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
