Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
After power loss, and reconnect fridge won't get cold
Lost power, while it was out, shut the main breaker off to the house. When it came back and breaker was back on, fridge will not cool, and the freezer isn't working either. Can hear it running, but not cooling at all no matter what temp it's set at.
  • tjridder Jul 22, 2009
    it's been running for 3 days... with absolutely no cooling at all.
  • Randy Hough
    Randy Hough May 11, 2010
    How long have you let it run before checking temp?
    President:
  • 2,559 Answers
Sounds like it may be locked in thermal overload,How long was the power out?
Posted on Jul 22, 2009
Ge fridge controls not working
try unplugging it for a few minutes then plug back in see what happens
Feb 23, 2015 | GE Refrigerators
Disconnected the baseboard heater - turned power back on - no power
If the breaker (you mean from the main board?) is turning off there is a line fault or short somewhere. If the breaker is not kicked off then there is a loose connection or maybe a small blown fuse in the base board heater unit itself.
Feb 17, 2014 | Heating & Cooling
E442 Fridge Was noisy, now trips mains power :(
Sounds like the compressor is grounded out causing the breaker to trip, but it could also be wiring, but if I recall most things in those type of machines reduce down to 12vdc and that wouldn't blow the breaker.
Jun 03, 2012 | Fisher and Paykel Refrigerators
Main breaker can't be stitched back on after neighborhood power outage in our home, yet all the neighbors have power except us! Why are we the only ones without power?
You're trying to load the entire house on the main breaker all at once. There significantly less stress on the main breaker if you start it like this:
1) Shut off all the circuit breakers.
2) Turn on the main circuit breaker.
3) Turn the other circuit breakers on, one at a time.
May 06, 2012 | Electrical Supplies
We have 2 breaker boxers for my house. 2 nights ago, a breaker got tripped, (too many air conditioners i'm guessing) and i flipped it back and all we well...almost. The power was lost upstairs and came...
Your main breaker may be problematic... GO to your master panel... the one with the meter, and reset everything, and on any sub panels reset everything.... Good Luck...
Jul 23, 2011 | Challenger Circuit Breaker
Where is the main switch to shut off the power in the house? I was vacuuming and the power went out in various areas around my condo. I think I have isolated the breaker and want to change it but I do not...
In some condos/apartments the main breakers are located outside. This is because the meter and incoming service are some distance from the local panel. Perhaps your breaker isn't bad, but the additional load of the vacuum caused it to "trip" Unlike some brands the Bryant don't show a trip indication other than the handle moving. Try turning this breaker completely off, ( if it was tripped, it will click) then turn it back on. If you do locate the main outside, and decide to change the breaker inside, be sure to "lock out" the main disconnect while you're working on the panel.
Nov 11, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
220 appliances in house all out.lights up but either dont heat or wont bake .lightning could be culprit but never lost tv reception.dryer runs ,no heat.water heater out.stove lights up wont get hot.shut...
Sounds like you have lost one leg of your power
Think of it like this
You an upside down "Y" at the top of your breaker panel
220 - 240 volts come in the Y and break in half 120 volts to each leg of the "Y"
A 220 Volt breaker straddles both legs a 110 volt breaker only contacts one leg
I suspect that you have lost one leg
Possibly at the main breaker ( top most)( main disconnect) in your panel
If you have a tester with the capacity to test 240 you can test the two top lugs where the main wire comes in Test them together That is one probe of your tester on each wire you should show 240+/- volts
Then you can move down through the panel 120 +/- on each leg
Hope this helps if you need more just let me know
Scott
Mar 16, 2010 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
WATER DISPENSER NOT WORKING
It might be that you have a restriction at the water supply line serving the fridge. Check it for good flow (have bucket and towels handy!) If supply line is good, then move onto the fridge to check the water inlet valve(s). as newer models have 2 or 3 inlet valves, a main water valve for the entire unit, and possibly one each for the ice maker and water dispenser past the main inlet valve (solinoid).
You can check these by simply shutting off the main supply to the fridge from the house water line 1st, and then removing each water line from the supply side of the fridge and seeing if you have water flow from the house to the valve side. If you do, then reconnect the lines to the fridge valves and see if you can get water flowing to the other side of the solinoid/valve when you have someone try to get a glass of water from the water dispenser, etc.
It is possible that there is an obstruction in the lines, by not very likely. Normally it is a failed water valve(s) (solinoid) that causes low flow or complete loss of flow, especially if you've changed the fridge water filter or replaced it with the "cap" which eliminates filtering of the water.
It is that you'll likely have to replace at least one, maybe more, of the fridge inlet water valves. If you have the time, try to zero in on the failed one by bypassing each, one at a time, until you get water flow. That way, you'll only have to purchase just the replacement valve needed to get things working again.
Jul 07, 2009 | GE GSH25JFR Side by Side Refrigerator
Sub zero 700tc/fan runs but no compressor
A check of your breaker is in order. From your description the breaker could be week. If so the breaker my not cut off all the way and still allow enough power through to opperate the fan but not the added load of the compressor.
I have seen this a few times and it always confuses me too. Check the circuit by maybe moving the circuit on the breaker to a different one then retry it and see if the problem is gone. If it is then replace the breaker if not then its time to use a volt meter or call a repair person. And this is because there are a lot of what ifs that have to be covered to get to the root of the problem if this is not the trouble..
Please lket me know whow this works out. Rate me as high as you can and thank you for using fixya.
Apr 28, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Mar 21, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
271 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
