Question about 3d Rose Londons Times Funny Cow Cartoons - Cow Country Club - Golf - Light Switch C
Cannot turn off power
On my 36 volt club car, it I turn off the power with the key switch I can still go foreward and reverse. I disconnect the wires from the key switck, same problem. A bad selonoid maybe? stumped! The cart is bout 7 yrs old, good batteries.
    President:
  • 2,559 Answers
Sounds like you may just have some bare wires touching,Trace the wires from the ignition switch.
Posted on Jul 22, 2009
  • 71 Answers
Maybe a shorted solenoid ( two large screw posts). They should only short when 36v is applied across the two small screw posts.
Using a voltmeter, measure voltage across the two small screw posts on solenoid. If you measure 36 volts with key switch off then look for bad switches and/or bad wiring.
Posted on Nov 08, 2009
36V club car. New batteries, new controller, new solonoid, new micro switchs, new cables. It will not make a sound and it will not go. What is wrong?
Verify that all battery cables are wired correctly. Should be in series-- neg to pos , neg to pos etc. Then measure total voltage at the main positive and negative battery posts, should be close to 36 volts. If we are good there then measure the voltage at the small posts of the solenoid when the f/r switch is in either position, the key switch is on and the pedal is pressed. I would do this only if the rear wheels are off the ground. Lets say that you do measure 36 volts there, that would mean the solenoid is probably bad.
Now lets say you don't measure 36 volts. Normally there is a small red wire connected to the main positive battery wire at the charger receptacle, it feeds the key switch, key switch comes back and feeds the micro switch on the back of the f/r switch, then to the positive side of solenoid. So connect black voltmeter lead to main negative and with the red lead measure voltage at solenoid. If no voltage keep working back until you find the trouble.
Assuming you have good voltage on positive side, now we check negative side. You probably have a fan shaped black plastic object mounted on the frame under the seat. It's named V-Glide. When you step on accelerator pedal a micro switch in the v-glide closes and provides negative to the solenoid. I hope this helps.
Jun 23, 2017 | Golf
Solenoid clicks. Why doesn't it go?
Need to know what kind of cart you have. Ezgo, Club Car?
36 volt, 48 volt ? for ezgo look at manuf. code, for club car serial number has the year. Then maybe we can figure out something.
Sep 09, 2015 | Golf
Golf cart wiring
Its been a wile but if I remember right it goes from the solenoid under the cart (pass side) to the key switch (the other wire is probably volt meter) then micro switch,green wires from micro switch to controllern. Inspect all spade connections
Jan 30, 2013 | Cars & Trucks
Wireing a 24 volt go cart
Obviously will need more details on what you have there already Tom, but with DC current, in order to reverse direction, you simply reverse polarity. Take a power window on a car as an example: Although 12 volt, same basic idea and principles apply. When you hit the switch in one direction, + power is sent to window motor through one wire, and negative through the other wire. When you hit switch in opposite direction, the wire that was showing + 12 volts, now becomes ground, and the wire that was ground (-) will show 12 v + current flowing. The reversing of polarity (current) is done withing the switch and how it's wired. So basically, if you take the 2 wires going to motor, and reverse them, the motor should turn in opposite direction.
Nov 12, 2011 | Razor Electric Go Cart
My F-150 has dual tanks and the rear tank empties while the switch is on the front tank.A full rear tank will empty out while on the front switch
Your switch is bad. Run an impedance test on the switch with your volt meter...If you don't have a volt meter, take it to a shop.
Jan 21, 2011 | 1991 Ford Club
No reverse lights on 2000 grand am or shift out of park lock
try disconnecting the plug off the reverse light switch (on the transmission) and bridging out the 2 terminals and then see if your revers lights work if they do replace the switch
Oct 01, 2009 | 2005 Pontiac Grand Am
Club car on off switch gets no power
This is a gas or electric 48 v or 36 v? what year model? F/R switch is a lever or a rocker arm? Club cars have made many changes over the years.
Sep 01, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Have 36 volt club car w/coils
Recheck your battery wiring. The batteries should be wired in series, neg to pos to neg. I believe one of the batteries behind the driver's side is the main negative and one on the passenger side is the main positive. There is usually a #6 green wire coming from the for/rev switch to a positive battery post, however , it might be a different color, but that one is the reverse wire, It can be on any positive post, just count the number of batteries between green wire and main neg, multiply by 6 and that would be total reverse voltage. If wired correctly all 6 batteries are used for forward.
Jul 13, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Need a schematic for a club car golf cart
new batteries-36 volts--can,t get power to motor------ help please
Apr 23, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
3d Rose Londons Times Funny Cow Cartoons - Cow Country Club - Golf - Light Switch C Logo
470 people viewed this question
Top 3d Rose Electrical Supplies Experts
Ronald Prier
Scott Jelt
Scott Jelt
Are you a 3d Rose Electrical Supply Expert? Answer questions, earn points and help others
