Question about Dometic Rooftop RV Air Conditioner
A/c compressor cuts off
I HAVE A 92 MAZDA B2200 THE COMPRESSOR WORKS IF THE SWITCH IS ON THE #1 SPEED BUT IF MOVED ANY HIGHER THE COMPRESSOR CUTS OFF AND FAN ONLY BLOWS . ANY HELP APPRECIATED
  • 158 Answers
Replace the switch
Posted on Jul 22, 2009
92 mazda B2200, new ac switch put on, you can hear compressor click on but only hot air blows out
take it to an accredited ac specialist shop and have the gas pressure checked
most likely a leak in the system
Aug 06, 2016 | Mazda Cars & Trucks
My 1989 mazda b2200 standard will start but wont idle unless key is turned over to start position. i have a 1991 auto mazdab2200 for parts.
check for power to the idle fuel cut-off soleniod at carburator to see if it goes dead in run position. might be a faulty ign switch or bad fuse.
Mar 14, 2014 | Air Conditioning and Heat for Mazda B2200
Mazda b2200 heat
It is likely the electrically operated blend door is jammed and the motor is damaged. If that is the case check on eBay for a heater beater brand kit for Ranger and Mazda, as they are the same vehicle or if not the dash must be removed to service the blend door inside the ducting.
Mar 14, 2014 | Cars & Trucks
I own a 1993 mazda b2200 pickup and put 2inch drop spindals on it and the outer steering components hit the factory tires and rims how can i remidey this
i understand the problem chad skeet69 is having w/his 1988 mazda b2200. why would you lower a b2200? doesn't that kind of defeat the purpose of hauling water with it? one way to fix your problem is to move. get expert help from a certified mechanic. it was fun talking to you in emails but i'm not interested in those kind of activities.
Jan 20, 2010 | 1988 Mazda B2200
Can a bad ignition switch cause the truck to die or idle bad? 1988 mazda b2200
Yes, bad ignition switch can cause that, did on my B2200.
Apr 16, 2009 | 1988 Mazda B2200
Ignition wiring diagram Mazda B2000 1986
my 88 mazda b2200. none of the lights or fuel pump come on when i turn the key over, but i know the wires aint hooked up. im just trying to figure out where they are located
Mar 25, 2009 | 1988 Mazda B2200
Igniton switch installation
Remove column cover, remove wiring harness, cut a slot in 2 bolts (originally breaw away bolts) holding swith assembly to steering column ??? remove put in new one
Dec 24, 2008 | 1988 Mazda B2200
Air conditioning controls
Sounds like a bad switch.
Dec 15, 2008 | 2004 Mazda 6
Dometic Rooftop RV Air Conditioner Logo
141 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
