Question about Toshiba 50HM66 52" Television
No pic woke one morning, turned on tv and no picture, i did have this the lamp or something else.lamp part # is Y66-LMPBest Buy tells me i can use lamp #72514011x
  • 537 Answers
I think you can use the Best Buy part. I found a source for that part and they charge $249.
You might first verify that the lamp is bad before spending $200-250. It could maybe the ballast that fires the lamp, or the color wheel inside.
Check for any loose wires for your video source (input to Toshiba TV)
Posted on Nov 20, 2007
I have had a total of 3 blown bulbs. The last one worked for about 5 hours. When I woke up the next morning and turned the tv on it made a loud cracking sound and the bulb busted. What could be causing...
Every set that uses a lamp for brightness has a ballast----it essentially provides power to fire the lamp----power in to the ballast will be around 300 volts DC in most sets and the output to the lamp over 14,000 volts with lots of RF---like spark plug wires.
Dec 08, 2012 | Televison & Video
I was watching tv this morning and my set made a loud popping sound and the screen turned black. A red light appeared which read lamp and there was a burning smell. I unplugged the tv waited for a few...
The lamp is most likely needing replacement. Replaceing the lamp is a very easy proceedure on that model.I am pasting a pic where the lamp cover is located on rear cover. Remove the screw and the lamp is behind the lamp door.
Jun 08, 2011 | Mitsubishi WD-57734 57" HDTV
My Samsung HLR5067 was working fine last night. I left the house open and it dipped in temp (only to 40 degrees or so though)...Woke up this morning and it wont turn on at all. Just beeps a few times,...
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
Dec 06, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Watched tv last night - ok.Turn on tv in the morning - no sound. Can I fix?
YES common fault you need new lamp located behind cover on side or front the front one is a little harder to get to if you have book shows you how.
The model number will be on old lamp look at lamp will be white or blown WHEN GET NEW LAMP DONT TUCH GLASS after replaced pic and sound will be ok
Nov 07, 2009 | Samsung DLP HL-P5663W 56" TV
TV turns off while watching it then turns back on after abt 1 min
TV needs new lamp as symptom shows existing lamp is weak and causing repeatedly on-off
Please replace lamp in TV, replacement procedure is written in user manual and it is not difficult.
Always buy Sony original lamp for TV safety.
Let me know if you need further help.
Sep 22, 2009 | Sony Televison & Video
How can I order a lamp for a toshiba 55hm66 with a lamp y66-lmp and how can I put this lamp in my tv
Check Lamp for your TV in Part Store and lamp replacement procedure would be mentioned in user manual of TV.
Jul 02, 2009 | Toshiba 50HM66 52" Television
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help.
Dec 26, 2007 | Protron PLTV-32 Television
Toshiba 50HM66 52" Television Logo
121 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
