Question about Dryers
I can't put the dyer belt back on (kenmore 60 series)
I took it apart, and fix the problem, but forgot which way the belt is attached to the wheels. Is there a picture some where?
    President:
  • 2,559 Answers
It is different for each brand but here is a general idea
Posted on Jul 22, 2009
    President:
  • 1,714 Answers
Watch the video
My kenmore 70 series washing machine wont spin. i took it apart and could see the belt off, but i couldnt figure out how to put it back on
just place the belt over the motor pulley
then get it started over the drum pulley it will stretch on by rotating the drum pulley
Mar 09, 2010 | Washing Machines
I have a Kenmore Heavy Duty 60 series Washer. The agitator is out of balance, so I took it apart to find the counterweight spring was not attached to anything. Where does it attach too, it is already...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
You should be able to see where the springs attach by looking at the base diagram.
Following also is the Whirlpool / Kenmore PDF on how the transmissions work but it also has a good diagram of where the springs attach.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I don't believe that the counterweight spring attaches to the brake.
Dec 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore dryer- remove fan to change motor on dryer.Do I need a gear puller to remove ? 7 yr old 90 series dryer ,seal drum came lose from damage to dryer when purchased. Did not relize damage until motor...
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
Mar 22, 2009 | Kenmore 659 Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore Washer Top Load Series 60 won't drain
The water pump is a belt-driven device actuated by a clutch. Your problem could be:
1. Stuck pulley - break it loose and WD-40 it
2. Broken belt - replace
3. Bad clutch - call repair or replace
There is almost nothing that can go wrong in the pump itself. It's probably one of these three.
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Putting dryer back together
from front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Sep 13, 2008 | Kenmore 63012 Electric Dryer
Need to replace dryer belt for kenmore series 80. The dryer is apart dont know how/where the belt should be installed
hi the belt is attached to motor find below shaft the screws ,fix the belt again assemble it
Sep 10, 2008 | Dryers
Elec. dryer
remove the front panel,find the idler arm wheel,the belt goes under the idler wheel and onto the motor pulley,put back together-mike
May 27, 2008 | Kenmore 65924 Electric Dryer
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Dec 24, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
