Question about DHD NTX-2006 Car Audio Amplifier
Worked for a few day's and now it will come on for 2 sec then off
I changed my Fuse, checked my ground and all my wires nothing i believe its in protection mode and i dont know how to fix it.
  • 15,935 Answers
Http://www.fixya.com/support/r2656152-amplifier_going_into_protect_mode
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Posted on Jul 24, 2009
98 Dodge Caravan keeps blowing the wiper fuse. Works for a few seconds then blows.
check for bare wires grounding out , wiper motor failure or wiper shafts seizing up and overloading the motor
using a bigger fuse will only result in the wiring harness burning out and possible fire in the car
May 21, 2017 | Dodge Cars & Trucks
I bought a Logik car radio but every time I switch my car on I have to set the station and the time all over gain.. I dont even bother to set the time because it changes back to Midnight every time I
you forgot to hook up wire to fuse box with all time connection to power even when car is off.if u connected thw stereo red wire positive black ground theres always another wire yellow/blue/orange that needs to be connected to constant power that wire once connected will have all ur memories stations set and clock.ned to check wiring
Mar 03, 2014 | Car Audio & Video
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
Have a ground and wire is running but will ark intermited
There are two items I would like you to do:
1) Change your contact tip and try again. Make sure the wire is running smooth thru the gun. If this not cure the problem then go to step two.2) Change your wire. If it is too old probably is rusted and not making proper contact.Hope this help.
Nov 30, 2011 | Welding Tools
1996 chevy 3500 7.4 vortec. the ecm fuse blows at the turn of a key
One of the power wire going from your ecm to a sensor or solenoid is shorting to ground. Get a wiring diagram and an ohm meter. disconnect the battery and start checking each wire measuring from the wire to ground. as you wiggle you will see the meter show 0 ohms when it is shorted. These are the hardest and most time consuming kind of electrical problems .good luck
Nov 21, 2011 | Cars & Trucks
The main problem I have having is I am getting power to my AMP but no power to the subs. I tested my AMP and subs in another car and everything worked so I know my hardware all works fine. I had someome...
okay , well you need to make sure all your conections are in the right spots, and that your IN LINE FUSE, between your amp and battery, the big glass one is not burnt, just take a look at the metal piece inside , if its a sold metal piece its good, if its burnt in half like a broken bridge it needs to be replaced. the next thing is the fuse on your amp, you need to make sure it is not burnt also. Check your remote that it is hooked up to the right wire. then check that your sub/speaker wires are connected properly and secure. YOUR GROUND WIRE IS HUGE HERE also. MAKE SURE IT IS GROUNDED TO A GOOD SPOT, YOU MAY HAVE TO MOVE IT AROUND A FEW TIMES TO FIND A GOOD GROUND!!!! if you check all of these things, it should work fine.. you can fiddle with your amp and bass settings levels. turn em up so when it works you know it, but not too much you dont wanna blow nothing :)
Mar 12, 2010 | Car Audio & Video
Radio is not working
Many radios have another fuse located in the positive wire. Maybe yours is one of them. Try the other radio directly from 12 V and see if it turns on. If it does, nothings wrong with the radio. It is the wiring or your fuse is integrated with other accessory fuses. Check all the fuses even if they are not the radio.
Jan 08, 2009 | 1995 Honda Accord
Wipers wont work
1.  Turn on your wipers and pop your hood.   2.  If you hear you wiper motor, then you do not need to check your fuses. 3.  If your wiper arms are moving freely, then your linkage from the wiper arms to the motor is disconnected and possibly broken.   4.  If the problem is electrical, do the following:      1.  Check the fuse, and check for power at the fuse.      2.  Check the wiper motor for ground. For a complete circuit, you need power going in and ground               coming out.  Check electrical connections for corrosion or poor connections.       3.  Get a wiring schematic and trace power to the wiper motor starting at the fuse box in the                       following order:           Fuse box           wiper switch           wiper motor      4.  In the rarest of cases a wiper motor or wiper switch is at fault.  I do not recommend replacing                 anything unless you have proof that the part is faulty. (ie. power going into the switch but nothing           coming out.)
Dec 21, 2008 | 1992 Honda Accord
NO Power
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key one. If only one has power the radio will not work. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Sep 03, 2007 | Dual XD-7500 CD Player
DHD NTX-2006 Car Audio Amplifier Logo
Top DHD Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Tygh Duval
Tygh Duval
Are you a DHD Car Audio and Video Expert? Answer questions, earn points and help others
