Question about Orbit Hardware & Accessories
My sprinkler system is not on consistently and is pulsating off and on. How can I fix this?
  • blanchetait Jul 22, 2009
    As I set all the times for each zone at 10 minutes - number 1 will come for a minute then stop, then come on for 30 secs. then stop, then come on again for a few minutes and stop. The above will be repeated at station 2 through 6. The water will run but sometimes it will not come out of the heads when it is stopped. Is it my control pad that is faulty or is the wiring faulty. Please advise.
  • blanchetait Jul 26, 2009
    I did this but the problem is it pulsates during the program. Each zone is set for a specific time and that is working. The water keeps running but the heads are not spraying properly - they pulsate instead of watering like they should.
    President:
  • 1,714 Answers
You must follow the programming directions on the door and set the zones for times to operate.
Posted on Jul 22, 2009
  • Craig Butler
    Craig Butler Jul 22, 2009
    What make and model are you using? There is a program switch for two or three different programs too (A, B & C). Make sure your slider switch is set to program 'A' for the programs you set is for program 'A'
  • Craig Butler
    Craig Butler Jul 26, 2009
    Do all the heads do this? Are you on city water or irrigation? You may have clogging in the little filters at the heads causing pressure and flow loss. Each head has a small screen type filter that catches debris. If you have a ditch pump, this could be your problem. Let me know and we'll figure something out.
Display pulsates...doesn't allow me to run Manually - when I push Manual read out displays OFF...doesn't sequence to next station
Unplug it and take out the battery for a minute to see if it resets. If it does not, you need to replace it.
Apr 18, 2015 | Irritrol RD600-INT-R Rain Dial 6 Station...
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
A garden hose with an internal diameter of 1.9 is connected to a (statoinary) lawn sprinkler that consists merely of an inclosure with 24 holes each 0.13 cm in diameter. If water in a hose has a speed of...
let us consider the velocity of sprinkler is V2 rate of mass flow will same at a time so incoming mass flow = outgoing mass flow so from the principle of continuity A1 V1 = A2V2 since sprinkler is is N = 24 then A1V1 = NA2V2pi* (D1 / 2)^2 *V1= pi*(D2/2)^2*V2V2 = D1^2*V1 / ND^2V2 = (1.9x10^-2)^2 *0.91 / 24*(0.13x10^-2)^2V2 = 8.1 m/s^2
May 14, 2014 | Garden
I have a Nelson Pulsating sprinkler and can't figure out how to make it go all the way around
See if the stop that makes the sprinkler reverse by hitting the adjusting rings can be lifted up so that it doesn't hit the adjusting rings.
Gary
Jul 22, 2011 | Nelson Garden
My rain train will not spin and travel consistantly. Water will come out of the spouts, but it will often just sit there and spray water in the same place - not spinning or traveling. I have lubricated...
You will need to boost your water pressure... it needs 40-60 PSI to work correctly...
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Mar 23, 2011 | Nelson LR Rain Train Traveling Sprinkler...
I need assistance with properly setting the water flow, range, and rotation of the 993hps Gilmour Impulse sprinkler and the 967hzs Impulse Spike Base Sprinkler. There were not directions with the products...
For some simple instructions check out the "additional information" section at http://www.gilmour.com/Watering/Hose-End/Sprinklers/Large-Coverage/Metal-Head-Impulse-.aspx. If your sprinkler doesn't rotate, ensure that you haven't lowered the water pressure by opening another faucet elsewhere. My sprinkler doesn't rotate as freely as it did when it was new, but it probably just needs to be taken apart and cleaned and greased.
Aug 04, 2010 | Gilmour Mfg Metal Impulse Yard Sprayer...
Hardware & Accessories Logo
170 people viewed this question
Top Orbit Hardware & Accessories Experts
appman67
appman67
 Kenneth
Kenneth
Andrew Taylor
Andrew Taylor
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
