Question about Pentax Optio 33LF Digital Camera
My camera freezes
I have a pentax optio 33lf and have just bought a sandisk 2gb sd card for it. anyway when i first put it in the camera it takes a couple of shots and then thats it, when i next turn the camera on the lens comes and nothing else happens.
    Problem Solver:
  • 6 Answers
This camera supports only 512 mb sd card. If you use any bigger, it freezes. Tried with 1 gb and 2 gb and freezes, while 512 is just fine for the size of the pics of this baby.
Posted on Dec 01, 2009
Sd card not formatting
Are you sure your card is an SD card and not an SDHC card? The 33LF works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Sep 21, 2013 | Pentax Optio 33LF Digital Camera
This camera accepts a 512 mb sd card maximum. If you try 1 GB or bigger, takes a couple of shots and freezes.
Mar 08, 2013 | Pentax Optio 33LF Digital Camera
What is the largest capacity SD Memory Card that can be used with this camera ?
For that age camera the max is normally 2gb SD card. Be careful you don't buy anything larger like a 4gb SDHC thinking it will let you just use 2gb as it is highly unlikely.
This link goes to a memory supplier which shows 2Gb as the maximum. Not that I'm recommending you get any from them, just an example.
http://www.memory-up.com/Memory/PentaxOptio333.html
Jan 22, 2011 | Pentax Optio 33LF Digital Camera
When I put my 2gb Sandisk memory card in my pentax optio 33lf, it turns on, the lens goes out, it takes a photo and freezes. What is the problem? If I take the memory card out, it works fine?
My 33LF won't work with even a 1gb Memory Card. It freezez up as you describe.So far it seems happy enough with 512mb cards. A camera shop operator told me that the capacity of the card exceeds the capacity of the camera and it seems he was right.
Jan 08, 2011 | Pentax Optio 33LF Digital Camera
Every time I put in a new memory card (this time I put in a 2gb Sandisk memory card) in this camera it always shuts off and I have to take out the batteries to get it working? What's wrong and what should...
My 33LF had the same problem with a 1gb Memory Card. I have replaced it with a 512mb card and it seems to be working perfectly. I was told that the capacity of the 1gb card exceeds the capacity of the camera.
Dec 09, 2010 | Pentax Optio 33LF Digital Camera
SD card problem
here is a list of compatable memory cards
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=42425
.. any SD or MMC card should work up to 4 gb ... so your 2gb should be ok .. i suspect that it may be damaged .. you can try formatting it in a USB card reader if you have one on your computer .. some laptops have the SD slot built in .. there was some compatability issues with memory cards for older cameras but there shouldnt be any with such a new machine .. make sure the contacts are clean and the "protect" switch (if any) is in the unprotected mode .. when you format the card it may take several minutes so give it time .. if you are going to take movies then its better to use a "high speed" SD card .. like the 133x mentioned in the above URL .. slow memory may cause missed frames or 15 fps instead of 30 fps record rates.. .
the specs on your camera do show SD and MMC compatability .but they dont show any brand preference .. .
Oct 06, 2009 | Pentax Optio 33LF Digital Camera
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
May 17, 2008 | Pentax Optio S5n Digital Camera
256 Sandisk SD card problem with an Optio 33LF
Optio 33LF Firmware Upgrade Information & Instructions: This firmware corrects "camera freezing & cannot display images" issues with Sandisk & Black's 128MB & 256MB Secure Digital Cards. This problem is occurred because Sandisk changed the manufacturing location from the Philippine's to China during production of the Optio 33LF. They also change the electronic chip used the SD Card which caused a compatibility problems with Pentax, Minolta, Palm and other digital device manufacturers. In turn this also caused a problem with Black's SD Cards as they are manufactured by Sandisk. Therefore, we had to release a Firmware Upgrade for the Optio 33LF to correct compatibility issues with these SD Cards. HOW TO CHECK WHAT THE CURRENT FIRMWARE VERSION: Confirm the current firmware version by pushing and "HOLDING DOWN" the "Right Arrow & Right Zoom" button located at the back of the Optio 33LF. While continuing to hold the "Right Arrow & Right Zoom" button turn the POWER on the Optio 33LF. The current firmware version will be displayed on the LCD. If the firmware version reads "Current Version 01.01.05.04" then your cameras firmware is up to date. If you do not have the current version, then please refer to the information listed below. Please be sure to upgrade your camera. You can download the firmware from the following link. Please be sure to follow the instructions listed below. Firmware Download: http://www.pentax.ca/support/digitalsoftware/fwdc113p.elf Firmware Update Instructions: Please refer bellow to learn how to upgrade the firmware on the Optio 33LF. Should you have any problems please contact our customer service department. I have included our contact information bellow. PLEASE NOTE: 1. It is very important that the batteries do not deplete during the firmware upgrade as this will damage your camera. Therefore, please check your battery indicator prior to the firmware upgrade. FIRMWARE UPGRADE #1. Save the attached firmware "fwdc113p.elf" to your Desktop. #2. Put a Secure Digital Card in your Camera. #3. Format the Secure Digital Card to be sure that no other information remains on the Card. (Refer to page 86 of your Operating Manual) #4. From your Desktop right click on the firmware "fwdc113p.elf" and select "COPY" #5. Double Click on "My Computer" you should see your "REMOVABLE DISK" #6. Right Click on the "Removable Disk" and select "PASTE" Once the "fwdc113p.elf" file has been copied to the Secure Digital Card, be sure to properly disconnect your USB device if you are using Windows Me, 2000 or XP. For instructions on how to disconnect a USB device with Windows 2000, please refer to the Optio 33LF Operating Manual. Now that you have the Firmware on the Secure Digital Card. #1. Be sure the Secure Digital Card containing the Firmware Upgrade "fwdc113p.elf" is in the camera. #2. Be sure that your batteries are fully charged as you do not want the
Sep 08, 2005 | Pentax Optio 33LF Digital Camera
Pentax Optio 33LF Digital Camera Logo
213 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
