Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Having a similar problem with the La Cie 500gb. Powerbook G4.
Powerbook G4 no longer recognizes the external hard drive. I've tried different cords, and a different computer. Same problem.
  • 5,660 Answers
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Posted on Jul 22, 2009
Want to free up space on my internal hard drive (Apple PowerBook G4) without
Mac do not waste space, I recommend you to use an external hard drive. Try to find one with twice capacity that your computer's hard drive.I mean, if your computer hard drive is 500Gb, then find an external drive with 1Tb
Oct 01, 2012 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
My computer says la cie external hard drive is corrupted - is there anyway to recover my files? I need them!
You can try a program like http://www.piriform.com/recuva
But if your hard drive is damaged you will need data recovery help. This guy does it remotely and just works for donations http://FreeDataRecovery.us
Jul 20, 2011 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
I bought a rikiki go 500GB La cie today, and it's making zooming and loud clicking noises, what's wrong?
Your hard drive is most likely dead, you need to call the manufacturer and have them send you a replacement, the warranty should cover this.
Mar 04, 2011 | LaCie Rikiki Go Hi-Speed USB 2.0 500GB...
My seagate hard drive cannot be detected on the desktop anymore. Any ideas what to do? I have a Mac Powerbook G4
am not so sure if this is a similar issue with iomega external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link.
Apr 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My powerbook g4 won't recognize my external hd or my web cam but it recognizes my ipod.
I am not really sure but i think the Camara and the External Hard Drive have to be compatible with Apple I think so you can use it. An IPOD is made by Apple so thats why your G4 recognizes it. I would just buy like a USB Drive. And also try to download the Drivers also and you can do that by google-ing it that sort of think. Anyways just use a windows based computer Bro its much more efficient. Let me know how it goes alright.
Oct 02, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Worked fine on my macbook but not by my powerbook g4 or any other computer
I would suspect a corrupted catalog file, these are the map that a comupter uses to find its way around the drive, they are also the first casualty when a crash corrupts something. Disc warrior will write a new catalog and fix everything. PCs do not see discs formatted for macs.
Aug 21, 2008 | Hitachi 500GB External USB 2.0 Hard Drive
Powerbook g4 - la cie 500gb doesn't mount.
no, but why not ask La Cie? They have pretty good support, and if your computer isn't recognizing it, you can feed them all the information they need by downloading a freeware program called Balarc advisor, which not only tells you everything in your computer, with model numbers for hardware and all of your software (with their unique codes), but will also inform you if you are missing any needed Windows updates. Once you know what you have, go to
http://www.lacie.com/support/faq/faq.htm?faqid=10338 You may need to download something from them for your poswerbook different from your g5..
Feb 29, 2008 | Computers & Internet
Programs quit when importing to or exporting from ext. hard drive
LaCie's drives are more for data storage and backup, than as a 'logical' drive accessible through applications. You may wish to consider that, during your use of the item.
Dec 12, 2007 | Computers & Internet
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
557 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
