Brother IntelliFAX 2920 Plain Paper Laser Fax
Problem for Brother IntelliFAX 2920 Plain Paper Laser Fax
I keep getting intermittent paper jams in the
By kshranko on Jul 22, 2009
I keep getting intermittent paper jams in the back. Not every time, just occasionally. Nothing can be stuck or jammed because I keep getting good copies too.
Best Solution
posted on Jul 22, 2009
Very Helpful)
KingDWS
Rank: Guru
Rating: 90%, 159 votes
if you have used the fax a lot or have used a cheaper quality paper the rubber feed rollers are slipping.
Open the unit up and use a bit of isopropyl alcohol on a paper towl and rub or clean the roller. Let dry and close it up again. That usually will clean enough to make it work again. If not the roller may need to be replaced.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Brother IntelliFAX 2920 Plain
Questions and Unsolved Problems for Brother IntelliFAX 2920 Plain
Do you recommend Brother IntelliFAX 2920 Plain Paper Laser Fax?
Answer
Answer
Hi there! I am trying to send a fax form the Brother 8070P and when I send it - it seems to go... (More)
Answer
How do I change the baud rate to 9600 on an HP Laserjet All in one 3015
Answer
changed ink cartridges and machine still says there empty.
Answer
When receiving incoming faxes, the lines of print are reduced in size, half line printing, lines are... (More)
Answer
i have an brother 2920 - but when i send an email i want to receive a conformation receipt to show... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Brother IntelliFAX 2920 Plain...:
Top Fax Machine Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Fax Machine Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
