Question about Jandy AquaLink RS2/6 All Button Dual Equipment -
I have an Aqualink RS 6 all button control panel. All the lights are on the inside panel and it is not responding. The outside panel origionally was not responding, but is now responding and at least I am able to run the pump from the outside panel to circulate the water. Any Ideas on reseting the inside panel?
  • 128 Answers
Check the inside and outside low voltage wiring connecting the control panel. Take inside panel to the outside panel and hook up. You might have a bad wire.
Posted on Aug 30, 2009
I purchased a home a little more than a month ago that has an Aqualink RS8 system installed. A couple weeks ago, we noticed that in the indoor control panel was not lit, so we checked the outside panel. ...
open the aqualink control box remove the top panel see if the 4 pin red connector is plugged in and tight if it is check to see if the one inside is connected if ok check to see if wiring is cut
Sep 27, 2014 | Jandy Aqualink All Button RS Control...
I have aqualink rs 6 model 8227 we had a power outage for about 5 hours when the power came back on it says firmware rev b 13 and establishing communications but it never does. I can turn everything on...
turn system off then try again make sure wire connecting to controller is plugged in and tight if wireless see if antenna is flashing green and red lights inside of case
Nov 03, 2013 | Jandy AquaLink RS2/6 All Button Dual...
Jandy RS 6 panel not working. After pressing reset button, all lights on panel come on and there is no effect from press panel buttons. panel reads "Rev 6700 C." Have pulled out red 4-wire panel...
check wire going from 4 pin to controller see if by 4 pins wires touching or try controller with short wire by system wire sounds like shorted sometimes cut by landscapers
Mar 30, 2013 | Jandy AquaLink RS2/6 All Button Dual...
I have Aqualink RS6. Screen is lit, but no display. Is they some thing I can check?
Check to see if all 4 wires are connected inside the controller (your inside wall unit) and also at the power center outside. After removing the cover outside you will see a red 4 terminal strip (4 wires) above the buttons. Above the buttons is low voltage, below the buttons where the relays are is high voltage, be careful.
Your inside controller (cover pops off from below) has the same red terminal strip that hold the other ends of those same wires. If you have a later model it may use a telephone type connection.
If it all looks good call a pool tech who should have a portable controller, he can plug in outside to see what happens. Good luck with it.
Jan 28, 2013 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Jandy rs4 indoor control panel lights up but nothing displays
trade controllers if when switched problem moves bad controller if problem stays inside bad wires or plug
Aug 18, 2012 | Jandy Aqualink Rs4 One Touch Control...
All lights are on the control panel. The message reads"6700 REVC" can't turn anything on or off.
Most likely a problem in the RS-485 communication between inside and outside Circuit boards.
Email Jandyrepair@gmail.com for Help
Aug 09, 2011 | Jandy Aqualink Rs4 One Touch Control...
I have a Jandy AQUALINK RS TELELINK KIT outside and I have an inside Rs6 control panel as well. The weirdest thing happens when the temperatures outside reach over 80 degrees. My RS and inside control...
power supply is overheating when it cool it comes back on replace or when it goes off see if you have 24 volts ac if not bad transformer if 24 volts check for bad wires
Jul 07, 2011 | Jandy AQUALINK RS TELELINK KIT
The panel back light on myh Aqualink RS All
I don't think so but go through your menu to see if the backlight is enabled. I have never heard of one burning out unless a surge or something fried the whole unit.
Nov 03, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy AquaLink RS2/6 All Button Dual Equipment -  Logo
228 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
