Question about HP L1702 17" LCD Monitor
There is a vertical thin line going up the center of the screen. It's appears when I turn the monitor on and the only time it disappears is when the screen is white.
  • 94 Answers
Change your vga setting and monitor setting by right clicking on desktop try using your monitor different htz setting in advance tab and monitor setting
Posted on Jul 22, 2009
A thin vertical line(Green) has appeared on the screen
Hi peterbb24 - Welcome to FixYa!
It seems like you're annoyed by this vertical line running across your screen. At first, it may seem nothing and wont bother you much but as an expert (and based in my own experience), I have to give my fair recommendation to test your screen while in BIOS mode and see if the problem continues.
How to go to BIOS?
1. Turn OFF your computer
2. Turn it back on and hit "DEL" key repeatedly until you see a screen like below :
Stay on this screen for several minutes (1 hour recommended) and see if you'll still see that annoying line. If the problem continues, then it's high time to send this monitor to the authorized repair center to get it fixed. Otherwise, the problem could be software-related which requires you to backup important files and re-install your operating system. Please refer to your system's user manual for the appropriate guide in doing operating system re install.
Thank you for using FixYa.
Feb 27, 2011 | Xerox XA3-15B (Black) 15" Monitor
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
Dec 17, 2008 | IBM NetVista PC Desktop
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 | NEC LCD
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Apr 09, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
HP L1702 17" LCD Monitor Logo
172 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
