I have an RCA D52W14 HDTV that does not want to power up. I press the power button, and it acts it wants to power up, but doesn't. The green light shuts off, then turns back on automatically, only to shut off again. This happens again once more for a total of three times on w/ the green light, only for the light to turn off. After about 10-15 minutes, the television does finally turn on, and seems to function fine. It was originally suggested that it could be the flyback transformer, but would the TV turn on at all if that was the case? I'm afraid my troubleshooting in regards to TVs is not very strong. I have read many similar issues, but no consistent solution. Thanks for any help
  • 8,617 Answers
Replace CP150 and CP114 that should take care of the problem. You can get the capacitors at the following link under RCA parts they send instructions
http://servicemanuals.vstore.ca/
Posted on Jul 23, 2009
My tv is a RCA D52W14 the green power light comes on then goes off the television takes a long time to turn on
Bad capacitors on the deflection board CP150, CP120 and CP114 very common for that model. You can get the repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv d52w14
replace the flyback 25296 and the CP150 and CP114 capacitor. You can get the flyback and the capacitors at the following link and they provide free installation instructions with pics so you can easially do the repair yourself. heres the link.
Jan 17, 2009 | Televison & Video
RCA tv model D52W14
That is an ITC222 chassis and likely the HOT has shorted, 2sc5588 Rca Part # 259899
You might also check Cp150 2200uf/16v in the 6 volt line, a common failure. Always replace Cp120 330uf/35v & Cp150 2200uf/16v and always resolder Cl031 & Cl032...
There is also a tech bulletin Tv-06003 Dated 12/8/2006 which states:
Replace deformed ribbon cable plastic connector BP005 on the flyback board. This connector is warping or bowing (May Not Even Look Like It) and causing poor connections to the ribbon cable. Replace Rca P/N # 258686.
Try putting pressure on the BP005 connector and turn the set on, you may find the set will now work fine. Replace connector and you may wish to replace the ribbon as well while you are doing the repair!
This set is notorious for failures like this and it is not uncommon to find multiple problems.
Hope this helps!
Bill
Aug 08, 2008 | Televison & Video
RCA D52W14
That model is famous for bad flybacks that shut the set down and there is no warning they just quit working. If you need further info please let me know.
May 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
548 people viewed this question
Top Televison & Video Experts
Electro Med Services...
