Question about Philips 32PT6441/37 32" TV
Lines across the top of the screen
I have a picture but on the top of the screen you can see a mirror image of the picture coming in or I get white lines across and top.
  • 1,694 Answers
Re: Lines across the top of the screen
Check Vertical output IC circuit for bad capacitor.............
also vertical power supply for bad cap....Last----replace IC...
Posted on Nov 20, 2007
0 characters
3 Points
Akai 13" TV/DVD Combo CTD-1390 White Lines going across the screen with enlarged images on screen.
Retrace lines. This fault is called so. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to CRT screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 28, 2014 | Akai Standard (CRT) Televisions
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
Horizontal lines across the top 3 inches of picture
what line started? from Left to right? or from top to bottom?
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
White lines across TV screeen
if these lines are just at the top of the picture then i would suspect an electrolytic capacitor in the vertical circuit.
May 08, 2008 | Standard (CRT) Televisions
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Philips 32PT6441/37 32" TV Logo
162 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
