Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I cant shut off my lawn tractor with the key
I have a lawn tractor that was a (basket case) I can start the tractor with the key but it wont shut off with key..I checked the switch and its fine. Its probably something simple but i cant seem to find it.
  • 148 Answers
I actually had the same problem with my tractor and it turned out to be that I had to run a second ground wire (ground to a separate point) that forces the coil to ground). My suggestion is to remove the flywheel cover and attach a wire (at a different point) to the coil and then start the tractor and when you go to shut it off. Turn the key and then just find a metal point on the tractor to touch the wire to and hopefully the tractor will shut off.
Posted on Jul 22, 2009
  • Mike McDowell Jul 22, 2009
    If this solution works then you can just permanently ground the second wire.
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
MY LAWN MOWER WONT START AND RUN UNLESS I POUR GAS IN THE CARB INTAKE . PUT NEW FUEL PUMP DIDNT MAKE A DIFFERENCE .WHAT IS THE ELECTRICAL PART ON THE BOTTOM OF THE CARB
The electrical part on the bottom of the carb is a fuel shut off solenoid. When you turn the key on, the plunger inside this mechanism retracts, allowing fuel to enter the carb. If you remove this it is easy to bench test with an alternate power source. Hope this helps.
Sep 11, 2013 | Husqvarna Lawn Tractor  25 HP 54in Deck...
Engine wont start after shutting off to refuel
You most likely have a piece of debris stuck between the needle and the seat inside the carburetor.
May 11, 2013 | Yard Machines 158cc Push Lawn Mower #11a...
19.5 Craftsman Lawn tractor does not shut off
All the ignition switch does is complete the circuit or break the circuit. It sounds like in this case the circuit is completed all the time. Try unplugging the wire plug from the new switch while the motor is idling and see if the circuit is broken and the engine shuts down. It could be you got a bad switch from stock. Rare but it happens.
Bruce
Apr 25, 2013 | Garden
Sear ltv 10 varidrive lawn tractor
OLDER SEARS TRACTOR WILL NOT SHUT OFF WITH KEY. STARTS FINE.. ANY IDEAS WHAT TO LOOK FOR?
Jul 23, 2010 | Sears Garden
My mower wont shut off with key
Under the cover that covers the flywheel on the right hand side there is a connector that is likely unplugged,this grounds the coil when you turn off the key and there by shuts of the motor.If this is not the problem then you likely need a new ignition switch.
Jun 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My mower quit. I changed the coil and it started
Sounds to me as if the replaced coil might of fried when you shut the tractor off, several older lawn tractors have a coil that has just one wire going to them and this is grounded out by the key switch to shut the tractor down what happens is when the key switch gets warn it sometimes will feed 12 vdc or battery positive power to the coils instead of shorting it out in which case when you replace a coil in a lawn tractor it is best to replace the ignition switch along with the coil. If this is not a electrical problem it could be as simple as a plugged fuel filter that juat happens to let enough fuel thru as it sits to run for a little while but not enough to run fulltime. Hope this Helps, Don
Oct 20, 2009 | Garden
I cant shut off my tractor with the key
the ignition switch grounds the coil in the off position.repace the switch
Jul 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Help With Troybilt Ride On Lawn Tractor
check your crank case for fuel,
bowls stick open an fills it up
if this is the case , you can buy a plastic fuel cut valve from lawn mower shop
todays fuel isn't very good
also try sta-bil fuel coditioner
May 30, 2009 | Garden
Tractor wont shut off with key
if it is an diesel mower - it will have a fuel cut off switch on engine.
Apr 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
252 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
