Question about Whirlpool 24 in. DU910PFG Built-in Dishwasher
Dishwasher has mold growing in it. Anybody know why this is or how to stop it from doing this?
Help! The mold is growing at bottom where it drains out.....
  • 640 Answers
If you can remove some of the mold do so,then goto home depot,lowes,supermarket and find c.l.r. (calcium lime rust) remover.Pour 2 cups in the tank with no dishes and run the longest cycle.After that do this once a week until its gone than once a month thereafter any questions let me know.
Posted on Nov 20, 2007
  • 213 Answers
Go to the grocery store there with the dish detergent is a product call dishwasher magic or jet dry has a dish washer cleaner as well. follow instruction on bottle to clean the dishwasher then switch to powder soap only use half of whats recomened on the box
What causes mould in dishwashers , cleaned it yesterday mould was thick in it what's causing this
The mold is caused by food particles not getting fully pushed through the drain hose when the dishwasher drains. The drain hose is corrugated, and bits of food particles can sometimes collect on the ridges and in the valleys of the corrugation. Given the right circumstances, this can cause a gradual buildup inside the hose, just like cholesterol in our arteries. The presence of moisture and lack of sunlight in the hose allows mold to grow on these food particles. You will want to remove the grates at the bottom or back of your dishwasher (usually removing just a couple of screws will do it) and clean with bleach water (a cup of bleach in a gallon of water) as far down as you can reach. After you have done that, replace the grate, put the rest of the bleach water in the bottom of the dishwasher and run a regular cycle (no dishes, please!). Why not just put the bleach water in and run the cycle? Because that will kill the mold, but will not remove its build-up. You want to remove the build-up first, as far as you can reach---it's easier to remove when it's live. Then kill what's left in the drain.
If your problem was serious enough, you may want to replace your drain hose, too.
Oct 17, 2011 | Dishwashers
Hi We have a 1 yr old Bosch dishwasher SGS45C02GB-06. It's stopped working for the second time in a year. It stopped mid-cycle and the water is not draining away or being pumped away; although you can...
Did you install the high-loop for the drain hose? If not, you need to pull out the dishwasher and make sure that the hose is not lying below the pump at the bottom of the dishwasher. This will usually fix this problem.
Jan 05, 2011 | Bosch Dishwashers
We have a ge dishwasher and it stopped draining yesterday and when we took out the filter it was filled with mold. The machine also makes sounds during the cycle
If theres mold it will also be in the pipes use a strong bleach with boiling water this should help to unbloke Very careful with bleach and boiling water they do react (bubbling).
May 17, 2010 | Dishwashers
Foul odor on dishes and in dishwasher after cycle
It is very likely that your dishwasher is growing mold, in this condition. If it is causing your dishes the same issue, it may be wisest to obtain a dishwasher cleanser(Several detergent manufacturers now sell dishwasher cleaning items), which will hopefully kill off any mold colonies growing in your dishwasher's blades, and in your drain cap.
Apr 23, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Major calcium build up. what will cut through it?
Hello there and happy new year as well
How to Clean a Dishwasher Dishwasher manufactures tell us that the inside of dishwashers should not need cleaning---after all, it is constantly being cleaned as you wash your dishes. You know better. There is a slimy feeling on the walls or door gasket of your dishwasher---or there is something black "growing" at the bottom of the dishwasher by the drain---or it doesn't smell very nice---or there is a white coating on the heating element (even manufacturers acknowledge this one as common). What do you do? The first thing is to try to prevent as much of this as possible: 1) Be sure your water is coming into the dishwasher at a minimum of 120°; 140° is even better. If your water heater is a long ways from your dishwasher, before you turn on the dishwasher you may need to run the water into the sink until the required temperature is reached. If the water is not hot enough, the detergent (even gel detergents) won't completely dissolve, and you get the slimy feeling on the walls and gasket of your dishwasher. You also foster the growth of bacteria and mold or mildew in your dishwasher. 2) Be sure you are using the right kind of dishwashing detergent. Manufacturers usually recommend using certain brands. That is because they have tested those brands in their machines, so they know they will work. Others may do fine, but they haven't been tested. 3) Be sure you are using the right amount of dishwashing detergent. Ironically using either too much or too little can cause similar problems. The amount you need depends on the hardness of your water, not the amount of food left on your dishes. Okay, you've got all that under control. Now, how do you clean the dishwasher? Problem 1: Slimy feeling on walls and gasket ---Use good old soap and water (yes, soap to clean soap residue!) and clean away. Be sure to rinse well. If you don't you may have suds coming out from around the door the next time you use the dishwasher! Problem 2: Something black "growing" by the grates at the bottom of the dishwasher ---You have a mold problem. This is also what causes a bad odor to "grow" in the dishwasher. The mold is caused by food particles not getting fully pushed through the drain hose when the dishwasher drains. The drain hose is corrugated, and bits of food particles can sometimes collect on the ridges and in the valleys of the corrugation. Given the right circumstances, this can cause a gradual buildup inside the hose, just like cholesterol in our arteries. The presence of moisture and lack of sunlight in the hose allows mold to grow on these food particles. You will want to remove the grates at the bottom or back of your dishwasher (usually removing just a couple of screws will do it) and clean with bleach water (a cup of bleach in a gallon of water) as far down as you can reach. After you have done that, replace the grate, put the rest of the bleach water in the bottom of the dishwasher and run a regular cycle (no dishes, please!). Why not just put the bleach water in and run the cycle? Because that will kill the mold, but will not remove its build-up. You want to remove the build-up first, as far as you can reach---it's easier to remove when it's live. Then kill what's left in the drain. If your problem was serious enough, you may want to replace your drain hose, too. Problem 3: Brown spots on the door gasket ---This is mildew. Mildew can also cause a stale odor in the dishwasher. Use the bleach water recipe to clean the gasket, and then run the rest of the bleach water through a cycle, just as for Problem 2. Problem 4: White coating on the heating element ---This is a build up of minerals, mostly from your water. You may have heard people recommend putting TANG® Drink Mix in the dishwasher and running it through a cycle. This does work to help remove the calcium from the heating element. That is because there is citric acid in TANG®. However, the sugar in it may contribute to other problems you have been trying to clear up. So why not just use plain citric acid---what an idea! You can often buy the crystals in a drug store or in the canning section of the grocery store---it is used for making jelly with a fruit that does not have enough acid in it to allow it to jell. Fill the dispenser cup with the crystals (3--4 ounces), and run a cycle. If the build-up is unusually thick, you may need to do this a second time. So, now you have a clean dishwasher! How do you keep it that way? After all, who wants to have to go through all of those steps every so often? The best thing to do is occasionally run it empty with a cup of white vinegar and a cup of baking soda. How often depends on your water quality, how often you use your dishwasher, how much food you leave on your plates, etc.o there and happy new year as well
Jan 01, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Our LG Dishwasher is less than one year old and the dishes that are left in it for a couple of days before it gets full enough to wash a load get mold on them
mold grows in warm moist places and the food scraps makes a great petri dish to grow your science experiment its normal during summer season in the cooler season fall winter early spring takes longer
Oct 06, 2009 | LG LDF6920 24 in. Built-in Dishwasher
Mold grows on dishes in bosch dishwasher
Put a bowl filled with 2 cups of clorox on the lower rack and run a wash cycle (nothing else in the machine) this will kill the mold spores in the machine, and clear the smell.
Jul 29, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
New Bosch dishwasher mold before cycle
The Bosch is a very good dishwasher and it is very airtight. I would suggest you NOT leave the dishes inside that long, and always use the Power Scrub Plus cycle if you have it. It will get the water as hot as possible so mold does not continue to grow in the plumbing and filters.
It is NOT the dishwasher unit causing the problem.
Jul 14, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Black Mold growing inside dishwasher
this is an easy fix use 1 part bleach to 10 parts water and wipe down this will kill the mold you may need to do this several times
Dec 08, 2008 | Dishwashers
Whirlpool 24 in. DU910PFG Built-in Dishwasher Logo
1,084 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
