Question about Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature
While the lights are on, they flicker every 10 minutes or so
  • 3 Answers
This is a common problem with that model. The EJ500C is designed only for standard incandescent lights, not chandelier bulbs, CFLs, etc. Replace it with the ST01C, and you'll be fine. Intermatic may even exchange it for you if you if you complain to them.
Posted on May 02, 2010
    President:
  • 1,714 Answers
Check the connections in the wire nuts in the junction box that it's mounted in, sounds like a loose connection.
Posted on Jul 22, 2009
Lights flicker off after 10 minutes
You need to check head light switch. It is shorting and the load protecter is kick on and off. May have to change the light switch.
Aug 14, 2014 | 1992 Dodge Dakota
2003 Hyndai Elantra oil light has started flickering, Why?
If it flickers at idle, it "might" be engine wear, especially if you are approaching 200,000 miles. It might also be a faulty oil pressure gauge sending unit which is a little more likely.
Jan 24, 2012 | Hyundai Motor 2003 Elantra
Hello, just recently started having a problem with my 98 grand prix gt headlights... while im driving at night my headlights will shut off and start to flicker after about 10 minutes of driving... if i...
COULD BE FAULTY DRL HEAD LIGHT RELAYS OR FAULTY DIMMER SWITCH.SINCE HEADLIGHTS TURN ON AUTOMATIC.TRY USING MANUAL HEAD LIGHT SWITCH ON TURN SIGNAL SWITCH LEVER SEE IF HEADLIGHTS STAY ON IF LIGHTS STAYS ON YOU HAVE FAULTY DRL HEADLIGHT RELAY.IF LIGHTS STILL FLICKER OFF.YOU HAVE BAD DIMMER SWITCH.
Jun 09, 2011 | 2006 Pontiac Grand Prix
Screen has started to flicker constantly. tv is 9 months old. When switched off flickering stops for about 5-10 minutes and then starts again
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Feb 23, 2011 | Samsung LN55C650 TV
Flickering headlights. the lights dim in and out while the vehicle is running the lights dont flicker right away it takes about 5-10 of running them n then they flicker and cut off and on. the wire is...
Go to Autozone or Oreillys for a free scan of both the computer and the alternator. It sounds like a Regulator is bad. There reason it works well the first 10 minutes is that the battery is recharging and the Alternator is steadily charging via the Regulator. Then when the battery is charged the Regulator is tapering the charge and providing just the amount of energy your car needs.
This provides an off-on cycle which is the flicker you notice. It is not normal to show up and should be seamless. You may have the type of Alternator with a built-in Regulator and will have to open the Alternator or replace it to change the Regulator. There may also be a Headlight relay they mentioned, but if you notice the flickering in the overhead Dome light with the engine running at different speeds it is more likely the Regulator.
Mar 02, 2010 | 1989 Lincoln Town Car
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Headlights flickering
This could be caused by a lot of different things,,but usually it is the fault of the Headlight Relay.
Try replacing the relay before going further.
Jan 30, 2009 | 1983 Ford Thunderbird
Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Logo
290 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
