Question about HP OfficeJet 7310 All-In-One InkJet Printer
Officejet 7310 APF up scans and copies fine APF down Paper feeds to glass and light goes half way then a gear sounds like it's spinning and then a message says turn power off then on again. Jerry
  • 41 Answers
Hi
it is a clear sign of harware ,,i would request you to get intouch with the harware technican who can open up the printer ,,,,,,because even i had the same problem
Posted on Jul 22, 2009
I have an Officejet 5510 all-in-one printer/scanner/fax. When do a manual print (laying paper face down on glass), it works fine. When I use the automatic feed the copies have black lines along the entire...
You need to inspect and clean the narrow glass and the white reference bar that sits above the narrow glass. Scratches, whiteout, and debris will cause the lines on scanned documents.
Dec 24, 2009 | HP Officejet 5510 All-In-One Thermal...
Printing works fine but copying or faxing results in large black lines across the whole page
You have a dirty scanner glass strip. If you open the cover like you are going to scan a book on the lft side you will see a strip of glass separate from the larger piece. This glass is the area use when you use the paper feed assembly. Dampen a piece of paper towel with window cleaner and wipe the glass strip. You may need to clean it several times if there is dried ink or something on it. Allow about 2 minutes to dry and then copy or scan something and it should be much better.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Unable to copy from scanning bed
There is probably a little switch that gets tripped when the document feeder is in correctly. This is preventing you from scanning from the glass.
Jun 02, 2009 | HP Officejet 7310 All-In-One Printer
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
HP OfficeJect 7310 Uses 2 Pieces of Paper when Printing Fax
Sounds like the feed rollers need to be cleaned or replaced.
Dec 03, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
