Question about Lasko 48" Xtra Air Tower Fan with Air Ionizer
My lasko tower fan gets power n wont blow air
My lasko tower fan gets power and the light turns on and it will rotate but it wont blow air out and i tryed cleaning it and still wont work?
    President:
  • 1,714 Answers
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
Posted on Jul 22, 2009
I found that the motor was open. I took the motor apart and found the negative side of the wire inside the motor color is red connects to the white wire which goes to the 5ufarad capacitor mounted on the unit was broken inside the motor. I soldered the wires togehter in the motor and covered with heat shrink. The motor now works fine on all three speeds. I hope this helps
ed
Posted on Mar 28, 2012
Lasko fan wont blow air
Sounds like the fan motor is the problem
Aug 31, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
My tower fan(not a lasko) but very similar cuts off when i put it to rotate.
Sounds like a short in the wire. Return it before it burns your house down.
Oct 10, 2012 | Lasko 2554 Tower Fan
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
Aug 29, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko ionizer tower fan works but does not blow air
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I had a similar fan which quit. I could sometimes get it to start spinning by banging on it. Finally took it apart. Lots of small screws, all small phillips. As I suspected, the "thrust bearing," which supports the rotating components, had become "stiff." I thought that it would be a non-friction (ball bearing), but it is only a bushing, with washers supporting the shaft. With the motor opened up, I greased the bearing with petroleum jelly, and reassembled everything. It is spinning very quietly now. Final comment - this is probably more work than the average fix-it person would want to take on, but it is doable. It took about two hours, start to finish. I could do it in less than one hour now that I know how to do it.
Aug 01, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
I have lasko fan sudenly it stoped oscillating can u help me with this ? Lasko 48" Xtra Air Tower Fan with Air Ionizer.Model 4820
I have the same issue, i determined the oscillating motor has a bearing failure. I need to find a replacement motor.
Jul 17, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko 2554 Wind Tower Fan
I have a Lasko HVB, but this might apply to your fan:
Without taking the thing totally apart, here's an idea you can try: The power cord on some models (like mine) has a "warning" tag. I had the damn thing all apart when I noticed this. (Well, who reads 'em??) Seems like there's a mini-fuse in the PLUG itself that, when it blows, there's nothing you can do about it except send it for repair to a factory authorized yadda yadda yadda. Who's going to do that??
If you plug in and NOTHING HAPPENS, here's what might turn out to be an cheap and easy fix: cut off a few inches of the plug end of the cord and go buy another plug at Ace. Heavy duty might be appropriate: don't think I'd want a lamp plug on this baby. Get one that's easy to install. Bring the cut off piece and they'll help you find exactly what you want.
If you want to open it up, there's a screw behind the Lasko medallion, remove that and you can snap out the grille. You can see where the cord comes in from the back of the blower housing. Test the line voltage. If you're not getting about 120VAC, it's the plug.
If that's not it, IMHO, without some knowledge or a schematic, you're screwed. That'd be me. It wasn't the plug.
-Chuck
Jun 08, 2008 | Lasko 48" Xtra Air Tower Fan with Air...
Fan will not work
open it. look for a wire that has become disconnected from careless factory assembly
May 11, 2007 | Lasko 2530 Elite WindTower Fan
Lasko 48" Xtra Air Tower Fan with Air Ionizer Logo
3,993 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
