Question about Doro DECT 850 Cordless Phone
Doro arc 3 phone
Just getting "searching" on the handset. line is good, but how do you reset it to the main menu's??
thanks,
James
SOURCE: Main handset won't work; additional handsets do.
Check that you have the larger power adaptor connected to the base unit.
Posted on Jun 09, 2007
  • 65 Answers
SOURCE: phone says searching
The battery may be weak. Or it is too far from the base. Try exchanging the two. take the handset near the base and see if it will link.
Posted on Jan 29, 2008
  • 31 Answers
SOURCE: No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Posted on Apr 16, 2009
SOURCE: doro handset is locked how do I unlock the phone
Had the same problem, thanks for the tip.
(Its the hash key that you must hold down, actually, it even got the key symbol on it)
Posted on Nov 18, 2009
ginko
  • 19396 Answers
SOURCE: I have a doro cordless
Hi.
Here the manual for the Doro Arc 3+1 phone: Download the DORO Arc 3+1 Twin Cordless Guide- Untitled- Click here to download manual.
Here also Doro support page.
Regards.
Ginko.
Posted on Feb 24, 2011
Hi, Bruce Kelly I have a Uniden DECT1480-3 That the screens on all hand set's say's SEARCHING. I can not get a dial tone so I am unable to make a call or recieve a call. Their is no dial tone and all of...
All of the handsets appear to have lost their
registration to the base and will need to
be first de-registered then re-registered.
It may be necessary to do this in three stages.
First be sure that all of the handset batteries
are fully charged.
1.
Clear one of the handsets of its registration:
hold down both the [END] and [#] keys
at the same time until the display shows the
SYSTEM RESET menu.
Since the handset is not recognized by its
base, select "Base Not Available".
Confirm the choice by selecting "Yes".
This handset will now display
"Handset Not Registered"
2.
With "...Not Registered" displayed, place
the handset into the base unit cradle.
The handset should now dieplay
"Handset Registering"
After ~30 seconds the display should show
"Registration Complete" and will have a
handset unit number.
If the unit shows "Handset 1" (doubtful)
then just repeat steps 1 & 2 above for each
additional handset in turn. This can also be
the route if you do not care what the numbers
are and do not exceed the maximum count
for your system ( some are 4, 5, or even 12 ).
If the handset is a number other than 1 you
may want to clear the base & re-register
all of the handsets:
3.
Using the now-registered and working handset
(number x), press both the [END] and [#] keys at the same time until the display shows the
SYSTEM RESET menu.
This time, choose "Deregister HS" and the
System Reset Menu will prompt you to
select from the list of registered handsets
which one you want to deregister: choose
one that is NOT the one you have working.
Cycle around deleting them all until only the
one that is working is left: select that one and
the system will be ready to start re-registering
all handsets again from Handset #1.
Start at process (1) above, then (2).
Good Luck!!
Apr 07, 2017 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
Phone displaying Searching
I get the same problem with my Uniden. Seller said batteries but it happened on multiple handsets. I purchased another of the same model so my extra handsets would work and I get the same problem. I am buying ANOTHER phone - different brand - and if it still happens I know it is Time Warner. (most problems are with them anyway - they blew my 60" TV and would take no responsibility. Too bad they have a monopoly.)
Dec 27, 2013 | Doro 520 DECT Cordless Phone
Doro handset is locked how do I unlock the phone
hold down the star key for 5 seconds, this unlocks the keypad
Oct 16, 2009 | Doro DECT 540 Cordless Phone
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
Apr 16, 2009 | Clarity C4230 Cordless Phone
Cannot stop Searching message flashing on screen
I emailed tech@doro-uk.com and within two or three hours got a helpful email suggesting the following:
In the first instance please try disconnecting the power to the base station and removing the batteries from the handset for 15 minutes or so. Then reconnect everything and check if this has resolved the fault. This will re-synchonise the handsets to the base station.
The problem is now resolved.
Thanks.
Apr 09, 2009 | Lands Phones
DORO NeoBio 10 Cordless Phone
The hand sets probably need to go through the 'registration' process with the base station. Look up the steps on how to do this in your manual.
One thing that the manual sometimes does not highlight clearly is that first you need to press and hold down a button on the main base station for a while until it beeps. Then you can go through the menu on the hand set to complete the registration process.
Aug 01, 2008 | Doro 530 Twin Cordless Phone
Doro 5065R +3 not working after replaced battery
I have replace my doro batteries with Duracell rechargeables, just make sure you fully charge them before you put them in the handset.  If you find after a time that the charge goes again, charge them again (in the charger you buy when you buy the batteries)! Hope this helps.  PS, do you know how to turn the answering machine on?
May 06, 2008 | Doro 730R Cordless Phone
May 16, 2007 | Doro 530 Twin Cordless Phone
Doro DECT 850 Cordless Phone Logo
202 people viewed this question
Top Doro Lands Phones Experts
castletech
castletech
Greg Cann
Greg Cann
IT Solution
IT Solution
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
