Question about Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher
Dishwasher will fill but not cycle
My dishwasher will fill with water and get hot but will not do anything else. I just replaced the hot water element and cleaned everything else under and behind washer. Perhaps its the motor? How can I test it?
  • 213 Answers
The motor on these dishwashers have been causing alott of problems. you might want to check your owners manual for warranty info. some of these models have 5 year warr. on the motor
Posted on Nov 21, 2007
How do i check serviceability of thermostat and heating element on bosch dishwasher
Is the dishwasher connected to the hot water line? It should at least get hot water when it initially fills and then keep it hot when it operates.
May 06, 2014 | Dishwashers
Kitchenaid KUDS02FRSS0 dishwasher. Stops mid-cycle, sometimes wash, sometimes rinse, sometimes dry. Must restart 4-5-6 times to get it to finish. When finally done dishes are clean, hot & dry....
Hi Dennis.
If the dishwasher is hanging on in the middle of the cycle it is usually the heating system. If the temperature of the water is going up after filling, then the element may be working. The element is tested using a multi meter set on Ohms to read impedance across the heater element contacts. If impedance is infinity (open-off limit), then the element is gone. If the element is OK, then the bi-metal thermostat or the fuse must be replaced. The heating assembly is located at the base of the appliance, behind the kick panel.
Behind the kick panel you should also find the tech sheet illustrating how to run the diagnostic cycle for this model. Run a diagnostic cycle to confirm that the problem is with the heating system. Drain, water sensor and inlet problems sometimes may also result in cycle not finishing.
You can find parts and diagrams for your dishwasher in this page.
Regards.
Ginko
Dec 08, 2011 | Dishwashers
My dishwasher will not clean anything. It starts the programme and then constantly beeps. HELP!
Hello
Check the water temperature. Should be 125 to 140 F. (this is important.. check your hot water heater to make sure that it is turned up well enough to give out hot water)
Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
Check the spray arm and pump cover for splits or leaks.
Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
Make sure the dishes are loaded properly, or dishwasher is not overloaded.
Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles
ALSO.. if you had the manual whilch you can get free, check in the manual to find out what is wrong if dishes do not come out clean
Aug 11, 2011 | Miele Dishwashers
My dishwasher isn't working, it fills with water then doesn't do anything. The water doesn't seem to be hot. Does it need to be heated before starting the washing action?
Try running your sink water till it's hot and then running the wash cycle. Not all washes have a quick heat element.
Dec 23, 2010 | Dishwashers
Not getting hot water to my dishwasher
Assuming that you dishwasher is connected to the same under sink hot water valve as your kitchen sink and that you run water in your sink until hot water really does arrive in the sink just before you start your dishwasher, your problem is probably a failed heating element inside your dishwasher. The other symptom of this heater element is cloudy film on your glassware after the cycle completes.
If the above is true, then replacing the element would be your next step.
Aug 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not hot nor warm
When you run the hot water at the kitchen sink until it is hot and start a cycle on your dishwasher, is water hot when you open the door after it stops filling?
If no, the diswasher is connected to the cold water line, not the hot water line. The water temerature entering should be a minimum of 120 degrees but no hotter than 140 degrees.
If the water going in is hot, but it cools down after each filling then the heating element has failed and needs to be replaced. When the heating element fails, the dishes, especially the glassware will be foggy and still dirty.
Please reply with what you find. Good Luck!
Mar 30, 2009 | Dishwashers
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Indesit DG6100W problem...please help!
    Hi, I have the same dishwasher and it fills from the cold supply, not the hot and it doesn't have a cold cycle as is previously suggested, as you will know kellyemb :-)
    The Indesit DG6100W does a fill from the cold and heats as it washes, so if it's sticking part way through, it could be the heating element. Have you tried opening the door when it sticks and seeing if the water is hot? The heating element went on ours and it kept tripping the electric whenever the it tried to start to heat the cold water. If it is the element, they don't cost much to replace, even cheaper if you know someone who can fit it for you! Ours cost us around £12 and hubby fitted.
    The only other thing I can think of is it might be the timer, like someone has suggested but how to reset it, I have no idea. I have seen on another website that a replacement timer is around £55 plus VAT, which is a little expensive.
    Hope you get it fixed.
    Jul 01, 2008 | Dishwashers
    It fills, but doesn't kick in to spray/wash
    Main pump not running?...then it will either be the program controller or the main pump itself.....I would guess the pump first.
    Jul 17, 2007 | Kenmore 15522 Built-in Dishwasher
    Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher Logo
    91 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
