SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
SOURCE: need 13'' magnavox tv/dvd combo code for dish remote
To find the right code first click here.
Next click on the "Remote Controls" section.
Select the type of remote you have (based on the receiver model) to view the remote control users manual.
Hope this helps!
SOURCE: error code E:13 is showing on the washer
Mine did it too on a light load. Set to reduced spin and rinse spin and everything ok. Think this code shuts washer down when spinning out of balance to protect damaging the unit.
SOURCE: forgot security code for nokia 1800
If the default codes does not work, you can try Master reset codes in any nearby shops. Getting the master reset code is the only solution for a forgotten security code.
Thank you for your inquiry, Dario Hernandez!
I see that you are having difficulty with your Frigidaire front load washer displaying an "ERR" code. Typically "ERR" stands for an error has been detected this could mean that you have a miscommunication within the control panel. I would suggest resetting your washer and you can do that by flipping the household circuit breaker off for roughly ten minutes. If you continue to have an issue with your washer I would recommend contacting a professional technician for a diagnosis to be completed. The technician will have the appropriate tools to pinpoint the part needed for repairs. Hope this is helpful information. -OOS
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Hello tseitlenok - Typically ERR indicates that the washer has detected an error. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If error code does not clear, I would personally recommend consulting a certified technician for an accurate diagnosis and to assist with the repairs.
