Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water not dispensing in side by side Whirlpool refrigerator
How do I change the solenoid for the water line in my side by side Whirlpool refrigerator. It is making ice however it does not dispense water. I checked the lines as well as the filter and everything is okay. Please help!
  • jjgdl Jul 22, 2009
    I checked and the waterline is not frozen behind the meat & veggie drawers. I should have mentioned earlier that when I push the water dispenser line, I hear no sounds.
  • charles farrow May 11, 2010
    make shure your cold water tank behind your meat and veggie draws, is not frozen and water can't pass threw before you change out solenoid.
  • 6,784 Answers
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source. Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced. Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on Jul 22, 2009
Whirlpool Water Dispenser not working and not producing ICE.
check the fresh water solenoid on the back of the unit theres a screen in the water line to it that maybe clogged also crak the line lose gently to isure water is passing through it if not? then change the water solenoid
Jan 15, 2010 | Whirlpool GS6NBEXR Side by Side...
I have a Whirlpool Imerial Series Side by Side that will not disp
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
Nov 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser not working on Whirlpool mod ED25COXFW01
Tryusing an hairdryer or defrosting the unit completely , this often getrid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace thewater valve, the dispenser solenoid, or the whole dispenser assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 13, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser no longer works.
Where the water supply connects to the Ref there is one water valve but, two solenoids. One for the water and one for the ice maker. An OHM meter will tell you if these solenoids are good.
Solenoids good;
Set the meter to volts and check if power is getting to the water solenoid while pressing the water despensor. No power, bad switch.
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water on dispenser Model#ED5CHQXKQ01
most likely you have a frozen water line to the dispenser. it could be inside the back of the refr section that is just too cold or inside the freezer door.
either one can be tested by allowing each to warm up for 15 to 20 minutes and see if you get water thru door.
do you hear a buzz from the water valve coil when you push the dispenser lever? if so then the water line is probably frozen somewhere.
Jan 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool American Fridge Freezer
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dripping from water dispenser
You may have something in the solenoid valve seat that is keeping it from closing fully - could have happened at the filter change.
Jul 19, 2008 | Whirlpool GS6NBEXR Side by Side...
Water stopped running in the dispenser
i ihave a side by side samsung rsh1dbbp with ice and water dispenser but the water has stopped working i was wondering if you could tell me how to get the front panel off to check the switches
Mar 16, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
162 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
