Question about HP P5302M Computer Speakers
Speaker hook up
I can't find where to plug in the speakers after they were pulled out
Re: speaker hook up
There is no green socket. just an electrical plug in.
Posted on May 01, 2008
  • 205 Answers
Re: speaker hook up
It would help to know what kind of computer you have, but the odds are good it's a green socket on the back of you computer.
Posted on Nov 20, 2007
4 Suggested Answers
SOURCE: My speakers all work, but the subwoofer sound lowers when they are all working
I have a Sansui Subwoofer and when i turn it on the sound coming out is very low, its very hard to hear, can anyone advice ??
Posted on Feb 22, 2008
SOURCE: Broken right speaker
Dear Bethann240
It is very difficult to rewire the right speaker( the one with the controls). The black cable contains an orange and black pair which drive the "big" speaker in the base. The white wire has the wires for the controls. That white wire is .090 in in dia. Peel back the white pvc insulation and you will find a layer of aluminum foil which is intended to shield the control wires.Then there is another layer of insulation. Peel that insulation back and you find SIX color coded lacquer insulated wires. Each wire is .010 in in dia. If you attempt to solder the severed wires together you will doubtlessly melt the lacquer and short the cable out. Twisting the wires together without removing the lacquer won't work. The satellite speakers were intended to be non-repairable, thats why the case is glued together.
The best bet is throw the right speaker in the trash and try to purchase a replacement from Altec or find a replacement in a flea market etc.
Posted on Jun 01, 2008
  • 5 Answers
SOURCE: how do i hook up speakers to my lcd?
go to Radio Shack or whoever is closest for audio cables, ask for a mini-stereo jack to RCA male jack, it should look like a Y with the stereo mini female jack on one end and two (one red one black or white) old style speaker jacks. These should take care of the audio situation. It might be better to consider adding a tuner or media center to help direct the sound.
Posted on Jun 22, 2009
  • 591 Answers
SOURCE: the speakers are plugged into the jack on the back
Check that your plug is completely inserted. Normally the Left Channel works, as it is the channel on the end of the plug. If the plug is only partially plugged in, it will connect to the right channel signal from the computer.
Posted on Dec 02, 2009
0 characters
3 Points
Hook your green and orange wires off the speakers into green and orange inputs on the back of your tower. Hook the round black cable off the a/c adaptor plug into the black input on the back of the right speaker. Then plug into an outlet. There is no software for these speakers.
Apr 02, 2011 | Boston Acoustics BA265 Computer Speakers
I don't know how to install my logictech Z523 speakers; they are hooked up but no sound and not installed; computer doesn't recognize them and my fiance threw out the instructions so I don't know how or...
Your "line in" from speakers should be plugged into the green (output) port on the back of your tower or the headphone jack on laptop. You will need to hook the 9 pin connector from the right speaker to the subwoofer. The yellow line from left speaker plugs into port labled "subwoofer" on subwoofer. Plug your power cord from speaker system into an outlet. Turn them on, adjust volume. There is no software for this product.
Mar 24, 2011 | Logitech Computer Speakers
How do I hook them up. Moved and can't remember how to hook them up. I have them on the side of the computer with plug in , one on the left side and 2 plugs on the right sound
speaker A should two cables running from it plug one end into speaker B a large RCA jack,
Plug the other end into your PC Sound card (speaker out ((( )
then if it's a active systems plug Power converter into A/C port on back of Speaker A
Aug 24, 2010 | HP JBL Platinum Computer Speakers
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
My Right port isnt working and i have no idea about these knds of things
The way computer speakers are hooked up, is you take your 1/4" main jack from the power speaker, and plug it in to your computer's adio out jack. Then you have to hook up the other speaker's 1/4" plug to a jack in the back of the power speaker (by power speaker, I mean the speaker that has the volume adjustment and on/off switch). Plug the power speaker's power supply in to the wall outlet, turn it on, adj the volume, and you should be in business. If the other speaker isn't working, it might have a pinched speaker wire or another problem may exist, but usually it's either a pinched wire or incorrect hookup.
Oh, one more thing to check, make sure you hook the other speaker to the right jack on the power speaker. There are two jacks on the power speaker, and one is for the left or right speaker only. Good luck, and hope this helps.
Jul 04, 2010 | Creative Labs SBS 330 Computer Speakers
Only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
When plugged into my tv they are not very loud, why please
Probably because your TV does not have a built in speaker amplifier. You'll need to hook up a small amplifier to your speakers. Hook up audio cables to the TV AUDIO OUTPUT and then to the INPUT of the amplifier. Hook the speakers up to the AUDIO OUT or SPEAKERS OUT on the amplifier. Probaly have to take a trip to a place like Radio Shack to get the correct cables.... Good Luck.
Nov 22, 2009 | Harman Kardon Harmon Kardon SoundStick II...
How do i hook up my speakers to my computer?
nearly every computer has earphone jack... plug the mini plug of your speakers into the earphone jack and you should be good to go...
Oct 14, 2009 | Boston Acoustics BA7500 Computer Speakers
How to hook up Philips mms 321 to a laptop via usb
I don't know of any interface that goes from speaker wires to USB. I think that we should go another way. You know soundblaster has many cards that will let you hook those speakers right up and its a very easy installation. I myself have Bose speakers hooked up to my soundblaster card and its wonderful. You can peruse the soundblaster cards here.
Its really easy to do and it will allow you to have great sound that you can configure for very high quality stereo.
I hope this helps. please remember to rate me.
Nov 13, 2008 | Philips MMS 321 Computer Speakers
Broken speaker
the only way is o replace the wires from end to end.. you may have to do some soldering inside the subwoofer and the satellite speakers
May 12, 2008 | Altec Lansing Multimedia Computer Speakers
HP P5302M Computer Speakers Logo
118 people viewed this question
Top HP Computer Speakers Experts
Weathers Ez System...
Are you a HP Computer Speaker Expert? Answer questions, earn points and help others
