Question about Intel Motherboard
I have a Gigabyte-GA-8SIMLNF motherboard and recently bought 2gb (2*1gb)of pc2100 DDR and am getting the no ram beep,it is labeled ecc ramwill this not work?
  • emmett_mcnam Jul 22, 2009
    yeah it turns out it is server ram will have to relist it on ebay, thanks guys
    Brigadier General:
  • 7,191 Answers
Your motherboard does not support ECC RAM. You'll have to buy a PC2100 nonECC DDR RAM. Also, it supports a maximum of 2 GB RAM, i.e; 2 RAMs each of 1GB in each slot.
Hope this answers your query. Thanks.
Posted on Jul 22, 2009
    Scholar:
  • 122 Answers
The memory that should work is advertised as PC2100 DDR266. make sure it is the correct speed. I have found sites that list this memory with your exact board.
Check here http://www.memoryx.net/ga8simlnf.html
also it may need non ecc as listed in the adds
4 Suggested Answers
map9966
  • 2351 Answers
SOURCE: New RAM, computer stays on intel screen and occasionally continually beeps
Hi DeezKelb, The continous beeps you are hearing is the Award bios telling you the memory is not seated correctly. Please remove the memory & re-seat the two DIMMS.
See Award bios beep codes, click on this link.
http://www.bioscentral.com/beepcodes/awardbeep.htm
If the beeping continues. Either boot into the bios & reset from there or reset the bios by moving cmos/bios jumper page 1-16 in you're user manual to clear/reset the bios. (Remember to set the jumper back to default). Boot the PC & enter bios to setup you're prefered settings.
If you're board still continues to beep download a free program called Memest86 & run the software which will test you're memory. http://www.memtest.org/ Scroll down the page till you are under the three Screenshots. Listed there is ** Memtest86+ V2.01 (21/02/2008) ** typed in red.
You have a choice of downloading software to creat either a bootable floppy disk or a bootable CD disk.
Bootable floppy; Download - Pre-Compiled package for Floppy (DOS - Win)
Bootable CD; Download - Pre-Compiled Bootable ISO (.zip)
You're Asus board can only run up to 2GB Max memory.
Main download web site for ASUS P4V8X-X.
http://support.asus.com/download/download.aspx?modelname=P4V8X-X&SLanguage=en-us
Good Luck!
Have more questions, feel free to ask.
Mike
Posted on May 04, 2008
ehsan_bba
  • 112 Answers
SOURCE: drivers
at first you need to identify what is the motherboard model. then go to the intel website, give mother board model. download it. and set up it.
Posted on Jan 20, 2009
  • 3 Answers
SOURCE: Intel DG31PR Motherboard not booting
You could try reseting the Bios settings using the jumper of the motherboard after installing the new Rams. Anyways ,its working, so don't do that now :P .
"If some thing is working, don't try to fix it" :) .
Posted on Jan 31, 2009
Hi Could you please advise the type and size of
According to the manual, to max out the board's RAM you'd need to install 2 1GB sticks of DDR RAM. It can support DDR400/333/266. 2GB is it's maximum capacity.
Jul 09, 2011 | Intel Motherboard
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
I want to extend the RAM memory on my NEC computer. The motherboard is a GA-8SIMLNF Rev.1.1. It has two memory slots and presently one slot is occupied with a PC2100U-20330-A1 256 DDR 133 CL2 memory. I...
Check your manual (Gigabyte will have the manual on their website), to make sure your motherboard can handle 1Gb of Ram, or more. Generally in my experience, medium aged motherboards handle 1GB per slot, max (mine uses PC3200, not PC2100, and will take up to 4GB in its 4 slots).
You'll want PC2100 ram (easily searched for on http://www.newegg.com), either in 2x512MB sticks, or a single 1GB stick for your open slots (bringing you up to 1.25GB).
Mar 01, 2011 | Intel Motherboard
Will gigabyte 7VM333M-RZ support 1 gb ddr2 ram ? thanks in advance for your answer
this information is from Gigabyte web site
Memory
  • DDR 333 (PC2700) / DDR 266 (PC2100) / DDR 200 (PC1600) 184pin
  • 2 x DIMM slots up to 2GB
For more information you can also visit the same http://ee.giga-byte.com/products/mb/specs/7vm333m-rz.html
good luck and do rate if got help
Dec 04, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
I recently bought ram for my compaq evo d510 sff, but my ram is not detected. as in the computer will not boot at all with the new ram. I borrowed ram from other desktops, and all of them work, one is...
here is what you should have. you cant mix mem types. you are suppose to have what is listed below. maximum amount is 2 gig. have to be pc2100 which is ddr-266
  • Compaq Evo D510 CMT 2GB Memory Ram Kit (2x1GB)
  • 2GB DDR-266 (PC2100) Kit (2x1GB
  • Oct 22, 2010 | Compaq System brd w tray for Evo D510 SFF...
    RAM Slot does not recognize more than 512MB ( 184 )
    Consider updating your motherboard bios.
    http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
    Also make sure that your memory is correct for this system:
    - Max. capacity of system memory: 2GB DDR or 2GB SDRAM
    - DDR x 2, DDR266/200 non-ECC, un-buffered memory
    - SDRAM x 2, PC133/100 non-ECC, un-buffered memory
    Jun 26, 2010 | Asrock K7VT2 Motherboard
    What is maximum supported sd & ddr ram for GA 8I845GV gigabyte motherboard?
    The maximum supported DDR RAM for your motherboard is 2GB.
    Check out this link for all specifications of your motherboard.
    http://www4.dealtime.com/xPF-Gigabyte-Intel845GV-ICH4-FSB533-P4-SKT478
    Hope u find it useful buddy..
    Aug 10, 2009 | Gigabyte GA-8I845GV-C (GBSA4LB)...
    ASUS MOTHERBOARD P4X-X CAN USE ddr 400
    pls see ur specs here
    http://www.baber.com/motherboards/asus/asus_p4xp-x.htm
    ur board only support following RAM specs u cannot use DDR400
    Memory
    • 2 x 168-pin SDR DIMM Sockets support max. 2GB PC133/PC100 non-ECC SDRAM memory
    • 2 x 184-pin DDR DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM
    pls rate me FIXYA for this help if u like
    Mar 13, 2009 | ASUS P4XP-X Motherboard
    PC Motherboard Memory upgrade
    From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
    Supports up to 2GB memory
    No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
    Feb 20, 2009 | ASUS P4B266 Motherboard
    PC2100 RAM
    Sounds like the ram is corrupt.
    If you were properly grounded installing it you should be able to claim warranty. Otherwise it was your fault.
    Oct 08, 2008 | Gigabyte Computers & Internet
    Intel Motherboard Logo
    1,683 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
