Question about Fisher and Paykel DEGX2 Dryer
DEIX2 does not dry - cleaned out lint trap, disassembled and removed lint from around lint trap assy., still not drying
  • 6,784 Answers
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Posted on Jul 22, 2009
Try resetting the heating element. It is a red located on the front of the heating element.
Posted on Jul 27, 2009
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Dryer is not drying the clothes
If it is taking a long time to dry, but still has heat, try cleaning out under the lint trap. Take the whole lint trap off and clean the panel and path the lint is sucked through. I did this to mine and it made a HUGE difference! There was a ton of lint packed around the panel and only a small opening left where the air flowed into the exhaust.
With our dryer (Maytag) I had to take the front panel off to get to the area where the lint was.
Jan 19, 2013 | Dryers
Clothes will not dry tried 5 times to dry them even cleaned out the lint trap and tube still will not dry clothes or towels
Bob you will probably have to change the limits or also called thermostats if you want to try this yourself. There is probably two of them, they are located down by the burner/blower assemble and not more than 1 1/2 around with two wires going to them
Unplug the dryer
locate the thermostats close to the burner . You may be able to remove the lint trap and lint trap cover. remove the wires from the thermostats and using an ohmmeter ohm across the thermostats . The needle on the ohm meter should peg all the way across if they are good. If you get nothing the thermostat is open and needs replacing. I hope this helps you , you are probably tires of working on it by now. Also there is a sight, www.ehow.com that may help you even more. Good luck, Mark
Apr 19, 2011 | Whirlpool Dryers
I have a whirlpool dryer (LER7646EQ2) that is heating but clothes take forever to dry and the lint trap appears to be trapping less lint
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 20, 2011 | Whirlpool Dryers
Clothes are not drying as fast as before. Lint trap is not collecting ling.
venting issue. check vent tube for restriction. A quick way to know if it is external is disconnect vent tube run a load of clothes if they dry well then it is the tube, if it is the same then it is internal and the dryer will need to be disassembled and cleaned from the lint trap back. Good Luck Tim
Nov 29, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Whirlpool gs dryer and while cleaning the lint trap a peice of papaer about 4x6 fell into the trap -how to remove? Can I still dry clothes w/o starting a fire?
Please DO NOT try using it with the paper in it. You will need to remove the back cover and disassemble the lint chute to remove the paper. When the back is removed you will see the chute assembly on the left side about 8 screws hold it together. There are 2 screws at the top under the flap that covers the lint trap that need to be removed also.
Nov 23, 2009 | Whirlpool Dryers
Electric dryer not drying. Lint trap clean
YOU MAY NEED NEW ELEMENT REPLACEMENTS AS IT SOUNDS LIKE YOURS IS BURNT OUT.
Oct 13, 2009 | Dryers
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
Fisher and Paykel electric top load dryer
Dd you try to unscrew the larger lint trap underneath the lint cup collector. My serivce person showed me how to do this and after a year I cleaned it out and was surprised how much lint was caught in there. My dryer was not heating and drying quickly, this helped the problem.
Sep 11, 2008 | Fisher DEIX2 Dryer
I want to know how to remove the lint trap (not just the screen but the entire assembly) from a Maytag Performa PYET344AZW front loading electric dryer. The lint screen will not even properly slide back...
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer.
To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen.
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
how-to-repair-a-dryer-1.jpgTHANK U.. RATE IT...
Sep 11, 2008 | Dryers
Fisher and Paykel DEGX2 Dryer Logo
844 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
