Question about Vehicle Parts & Accessories
My alarm fob broke. Bought a new one at the dealer for 35 dollars. then tells me it will cost 109 dollars to program. Can i do it myself
  • striker51151 Jul 22, 2009
    2005 kia sadona yes factory
  • Jeremy Awbrey May 11, 2010
    What kind/year car?
    Is this a factory alarm or aftermarket?
  • 20 Answers
There is an excellent step by step guide at this web site:
http://www.sorentosite.com/diy/keyfob/keyfob.htm
Even though it shows a Sorento, your Sedona should be the same. Just look for the black plastic box under the hood marked "Diagnostics" and follow the rest of the steps. ** WARNING ** You are putting your car's computer into programming mode when doing this. Proceed at your own risk and follow the guide EXACTLY.
Re-programming Key Fobs
By Redzman
Tools Needed:
  • 1 or 2 OEM Key Fobs.
  • 1.5 foot of electrical wire, with ends stripped, approximately 22 gauge. (Jumper Wire).
Steps:
  • Open the hood of your SUV.
  • Behind the battery on the drivers side is a plastic covered connector labeled Diagnostics.
  • Open the plastic cover on the Diagnostics port by pulling up on the edge near the FRONT of the vehicle.
  • Get your prepped/stripped jumper wire and place one end in conneMy alarm fob broke. Bought a new one at the dealer - 04.gif as shown in the pictures.
  • Run the other end of the jumper wire to the POSITIVE terminal on your battery, youMy alarm fob broke. Bought a new one at the dealer - 05.jpgust push it into the little opening on there so it stays in place for a few minutes.
  • Get into your vehicle with your key fobs.
  • Put one key into your ignition and turn to ON position, DO NOT start your vehicle.
  • If you just have ONE key fob to reprogram, when you turn the vehicle to ON, hold the LOCK button down for 3 seconds, the lights on the dash will go off, and you are done. Turn the key off, disconnect the wire, and try the key fob.
  • If you have TWO key fobs to reprogram, turn the key to ON, hold the first LOCK button for 1 second, then the second one for 1 second. Turn the key off after the lights on the dash go off and remove the jumper wire. Test both Key Fobs.
Posted on Jul 23, 2009
Lost car key and fob,I have the valet key but starts for a few second then shuts down and alarm goes off How can I disarm the alarm?
The Valet key is not is not a ignition key only men't to open the trunk ect. your dealer can replace and program a new key for you.
May 24, 2016 | Cars & Trucks
Key fob won't work even after changing battery, can only open and lock car using key, alarm won't shut off and keeps ringing
retry replacing battery new doesnt mean cant be defective if it is good than fob needs a relearn different cars have different relearn that you can perform but if the fob has other features such as start that will have to be done at dealer ----
Free Keyless Remote Fob Entry programming instructions procedures for all... look up your vehicle and will have instructions one how to program fob --will also tell if need to be done at dealer
Aug 02, 2015 | Cars & Trucks
How to reset anti theft alarm to get hummer to start
When the anti theft system was created,the dealers forgot to tell the new car buyers about how much the fob matters to the vehicle,without it,owners are stuck,your anti theft device is activated,you need to lock and unlock your doors a couple times with the key fob,not the key,and then you need to put the key in the ignition and start it,if you dont have your key fob,call your car dealer to get a new one,they are programmed for each car only,you cannot bypass it.if you lost your fob or never had it,whatever,you need to have the exact fob that came with that car from the factory,the key and fob have a chip in them that only go to that certain car,if you do not have it,then you need to buy a new one from the dealer or ebay and then you need to contact your dealer about programming the fob to your car,you might not have to have it towed if they have the documents from the car,the only other way is to get a junk car,with the steering column,key,fob and all computer boxes and door locks and switch them,(i just did that with a 98 dodge dakota,and it works.)
Jul 23, 2015 | PAC Electronics Pac Aoem-gm24 Add...
How do I get my alarm system to chirp instead of beep when it goes off or when I lock my doors with the remote entry key fob?
Check to see if your vehicle honks when you press the "lock" button on your key fob. Press the "lock" button multiple times in a row. Many devices won't beep unless you double-tap the button after locking. If the horn doesn't honk, but the lights flash, your chirp feature is probably disabled.
Use your keyless fob and ignition key to enable the audible chirp. The process varies considerably on different makes and models. You must usually consult your owner's manual, a dealership or the alarm manufacturer for the correct process.
Jan 29, 2015 | 2006 Hyundai Tiburon
Cant get into landrover fob not switching alarm and emobliser off bought new reciever still not working
Do you have the EKA code, if you do, then activate that code, info should be in the service/maintenence book.
If not, then you have to go to the dealer to check and reset the alarm system
Mar 03, 2010 | 1998 Land Rover Discovery
No Working key fobs, and new ones on the way
I KNOW WHEN I BROUGHT MY WIFES CAR THE DEALER SHOWED ME HOW TO PROGRAM THE FOBS FOR HER CAR NOW I'M SURE THAT NOT ALL DEALERS WILL TELL YOU HOW TO DO THIS BUT THEY SHOULD AND YES THE INSTRUCTIONS IN THE BOOK SHOULD BE RIGHT
Aug 25, 2009 | 2006 Chevrolet Corvette
Reset 98 cadillac catera alarm
You can get one from the dealer or on ebay.
I would recommend an aftermarket unit with car starter. Much cheaper, 2 remotes and starts the car as well.
Aug 03, 2009 | 1998 Cadillac Catera
2005 chevy cobalt lt fob programming
unfortunatly, that is usually a programming code that the dealer does not let out. that is one of there easy money makers. it cost me $180 at nissan to get mine done, because no one could help me there.
Sep 22, 2008 | 2005 Chevrolet Cobalt
Vehicle Parts & Accessories Logo
429 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
