Question about Lexmark P4350 All-In-One InkJet Printer
Lexmark x3350 will not pull paper down wheel will not grip but says no paper when some in it
    Genius:
  • 2,035 Answers
Feed the paper manually into the printer:
Place a sheet of plain A4 paper in the paper feed tray.
Move the paper support on the left-hand side to the left end of the paper.
Press the paper feed button.
If the paper does not feed, continue with step 2.
Check for any obstructions in the paper feed path:
Disconnect the cables from the back of the printer.
Open the front of the printer and check for anything that may be blocking the paper path.
Close the front lid and remove any paper from the paper feed tray.
Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
Posted on Mar 16, 2008
Paper not feeding properly; getting stuck
When paper feed improperly, 99 times out of a 100 it is the rubber wheels which pull the paper. They get worn out semi-quickly and lose grip. I suggest grabbing some rubber rejuvenator spray (link for it below. That'll be cheaper than replacing the wheels all of the time.
http://www.amazon.com/s/?ie=UTF8&keywords=rubber+roller+rejuvenator&tag=googhydr-20&index=aps&hvadid=7878381949&ref=pd_sl_2apby1usfr_b
I hope this helps and thanks for using Fixya!
** If this was helpful, please leave a great rating so others may benefit from this answer too! **
Sep 23, 2011 | Lexmark X5470 All-In-One InkJet Printer
My printer X3350 has trouble grabbing the paper from the paper tray. What can is the problem. I tried cleaning the grabber wheel. But it still won't grab the paper.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 21, 2011 | Lexmark X3350 All-In-One InkJet Printer
The Lexmark X3350 printer paper jam
Try this:
turn off you printer
unplug the power cable
lift you printer up
while lifting, put it in an upside down position
then shake your printer from left to right for about a min. or 2
then put the printer back to its normal position
turn it on
then check if the issue persist.
Feb 26, 2010 | Lexmark OfficeCenter X3350 All-in-One...
LOST MY ORIGINAL CD OF PRINTER DRIVER I WANT THE DRIVERS OF THE PRINTER LEXMARK x3350
Hello and Welcome to FixYa!
You can download your drivers from here
If you have Windows XP please click here
http://www.downloaddelivery.com/downloads/cpd/cjB3300EN.exe
If you have Windows Vista please click here
http://www.downloaddelivery.com/downloads/cpd/cjr3300EN.exe
if you have Windows Vista 64-bit please click here
http://www.downloaddelivery.com/downloads/cpd/cjs3300EN.exe
Hope this solves your problem.
If i was helpful, kindly rate me.
Regards,
Waqar
Aug 23, 2009 | Office Equipment & Supplies
Lexmark X3350 paper will not go through
you may have something inside on the bottom of the paper feed area what you should do is
1. unplug the printer
2. pull the paper out
3. GENTLY flip it upside down and give it a good shake
4. if you hear anything moving then put it down and take a flash light and look down and see if what ever was moving around is there.
5. if there is something there then take a pair of needle nose pliers or your hand and GENTLY remove after that plug it in and it should work
Aug 23, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Print Output
Try cleaning the feed rollers. these are the rubber wheels that actually contact the paper and pull it through. If they get dirty, their grip on the paper will be less than adequate. Just use some clean water, or perhaps some rubbing alcohol, and a clean rag to wipe them thoroughly.
Feb 11, 2008 | Lexmark X85 All-In-One InkJet Printer
Lexmark X3350 printing
i just fixed this problem.  first i bought a new (remanufactured 3rd party) cartridge off ebay and found it wasn't working either.
there are cartridge cleaning instructions in the troubleshooting help section that show you how to carefully wipe clean your cartridges.  follow that, it solved my problem.
Jan 29, 2008 | Lexmark X3350 All-In-One InkJet Printer
Lexmark x3300
I need drive prin lexmark x3350
Jan 07, 2008 | Office Equipment & Supplies
Lexmark P4350 All-In-One InkJet Printer Logo
983 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
