Question about Bosch Exxcel WFO 2264 Front Load Washer
E04 not draining
I have a exxcel 1400 express its showing e04 i have taken all hoses off and flushed them all out and cleaned out the pump checked the u bend and that the clip is not done up 2 tight! still not draining and still showing e04 help please b4 i take a sledgehammer 2 it
  • 4 more comments
  • jon sefton Nov 21, 2007
    sorry i ment f04,any ideas any1???
    and i can hear a humming from the pump but not draining still. gone over everything twice now!!
  • Mel H Dec 10, 2007
    The machine won't drain - there is a pool of water inside. I've run a wash cycle with the water in and that was ok but the same amount of water remained at the end of the cycle. I've tried to ask it to 'spin' but it wont do that. Any ideas?
  • cool-banana Jan 03, 2008
    Yes, exactly the same problem on a Bosch 1400 Exxcel - get the F04 error message. Have drained it and cleaned out the (unobstructed) filter three times now and it's still not working.
  • starrann Feb 09, 2008
    we cleaned out the hose and chech below for a clogged sock.. NOTHING>> still humming
  • JackCR Feb 19, 2008
    Also have Bosch exxcel 1400 which occasionally stops with F04 error code. Have cleared filter, all hoses, tubes, pressure vessel, etc, run on hot empty wash with powder, then hot with soda crystals, then hot with vinegar. Sometimes machine works fine, sometimes stops on F04 once full with water and unable to drain or spin. Pump humming and doesn't spin. Can get it to restart again by draining out water from filter hose then after most drained out it, set to spin will start again. Have tried with filter open and it appears pump is sticking and can sometimes get it to kick in when move pump spindles. It is strange that it is intermittent. Does the pump need greasing, is it just on it's way out and needs replacement or something else?
    Is it a design fault?
    As others appear to have same problem would be great to find solution to what appears to be a weak link in an otherwise great machine.
    Anyone know the cause and solution? Advice would be greatly appreciated. Will let you know if get any further.
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 16, 2008
What does E18 fault code mean on a Bosch exxcel 8 washing machine mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Washing Machines
My bosch classixx 1400 express washing machine drain pump sometimes does'ent work
bosch classixx 1400 express washing machine drain pump This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 13, 2013 | Bosch Washing Machines
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Oct 20, 2012 | Bosch Washing Machines
Bosch logixx 1400 express washing machine spin is not working . ALSO THE WATER IS NOT BEING DRAINED OUT IN THE NORMAL CYCLE
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Apr 10, 2010 | Bosch Exxcel WFX 145S Front Load Washer
My bosch classixx 1400 express is not draining off and has a lot of grey stuff on the clothes is this dirt
The error indicates that the machine has taken too long to drain the water. Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
  3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 21, 2009 | Bosch Washing Machines
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
  1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
  2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
Mar 01, 2009 | Bosch Washing Machines
Washing Machine Will Not Drain
you have got a blocked filter or pump the filter is located on the right hand side at the front of the machine down the bottom behind the plinth you can drain the water from there as well by pulling the small grey hose out pull the plug out of the end and place in a small bowl good luck when the water is out you can check the pump impeler as well clean the filter houseing and put it back all should b well unplug the machine b4 u start work
Sep 02, 2007 | Washing Machines
Bosch Exxcel WFO 2264 Front Load Washer Logo
1,278 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
