Question about InFocus LP 130 Multimedia Projector
How do i open to insert the bulb? - InFocus LP 130 Multimedia Projector
  • 2,237 Answers
Look on the bottom towards the front opposite the lens. there is a switch lever that you pull back, then slide the front plate away from the lens.
Posted on Nov 06, 2009
Change headlight bulb on pontiac g6
Open the hood and the connected that holds the bulb twists out with a quarter turn anti-clockwise turn. Remove the bulb, insert the new one without touching the glass of the new one. Insert and turn a quarter turn clockwise.
Dec 25, 2015 | 2008 Pontiac G6
How to change a headlight
Dec 25, 2015 | Pontiac G6 Cars & Trucks
How to replace bulb in front bumper turn signal housing 1995 jag xj6
hello,
  • Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
  • Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
  • Remove the front turn signal light unit in the bumper to change the turn signal bulb. Push gently on the inside edge and insert a blade between the bumper and the lens at the outside edge. Compress the spring and remove the lens. Fit a new lamp by inserting it into the plug. The side marker light is changed using a similar process.
  • Open the trunk to replace the rear fog light, stop light, tail light, reversing light and turn signal light. Remove the rear light cover and turn the bulb holder fastener 90 degrees counter clockwise. Remove the expired bulb, fit a new one and replace the parts, turning the bulb holder clockwise.
  • Thanks..
    May 21, 2011 | 1995 Jaguar XJ6
    How to replace stop light?
    Tail Lights
    The procedure for removing and installing turn signal light bulbs is the same as that for brake light and taillight bulbs. Only the procedure for brake light and taillight bulbs is described here.
    1. Before servicing the vehicle, refer to the Precautions Section.
    2. Disconnect the battery.
    3. Switch off all electrical connectors.
    4. Turn off ignition.
    5. Remove the rear light, as follows:
    6. Remove the rear striker mount cover.
    7. Reach behind the respective quarter panel trim and unscrew the knurled nut. Make sure the washer and spacer do not fall down.
    Taillight housing
  • Remove the rear light and disconnect the electrical connector.
  • Turn the bulb holder in the direction shown and remove from the housing
    1. Remove the bulb from holder.
    To install:
    1. Install the bulb in the reverse order of removal. When installing, make sure bulb holder engages in housing by turning in opposite direction.
    2. Install the rear light, as follows:
    3. Connect the electrical connector.
    4. Insert the rear light housing into the body opening.
    5. Insert the retaining bolt into the body opening.
    6. Insert the rear light into the cutout.
    Insert the rear light into the cutout in the direction of arrow
  • Slide the spacer and washer onto the retaining bolt, attach the knurled nut and tighten by hand.
  • Turn the bulb holder in the direction shown and remove from housing.
  • // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 31; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
    Dec 25, 2010 | 2000 Volkswagen Beetle
    How do I remove the front turn signal assembly so I can replace the bulb?
    Your turn signal bulb is a 1157A or 1156 bulb (either will work), and usually inserts into a connector
    that unscrews 1/4 turn counterclockwise, and comes out of a headlight-turn signal assembly on the
    front of the vehicle.
    Try: opening the hood and turning the bulb holder 1/4 turn counterclockwise, then withdraw the
    bulb base and installed bulb. replace old bulb by turning it 1/4 turn counterclockwise and
    pulling it out (the 1157A and 1156 bulbs are bayonet-base). Install the new bulb by inserting
    into the socket (properly aligning the 2 pins on the base of the bulb with the channels for them
    in the socket), and the rotating the bulb 1/4 turn once inserted.
    Now - test the new turn signal bulb before putting it back together - this insures that the installation
    of the bulb into the socket correctly aligned the (2) contacts in the base of the bulb socket.
    Then: insert socket into headlight-turn signal assembly and rotate clockwise 1/4-turn to install.
    Summary: remove socket by rotating 1/4-turn counterclockwise and pulling out.
    remove 1157A or 1156 bulb from socket by rotating bulb 1/4-turn counterclockwise and
    pulling it out
    installation is reverse of removal.
    Oct 23, 2010 | 1998 Subaru Forester
    How do I change front blinker bulb on 2003 chev impala
    First,
    1. Turn the engine off and open the hood. Pry up the two fasteners from the radiator air baffle with a flat head screwdriver. Move the baffle to the side to access the top of the headlight case.
    2. Step 2 Pull up the two metal rods behind the headlight case. These secure the case to the car. You may need your pliers to pull them up.
    3. Step 3 Gently pull the headlight case out to access its rear. On the rear, you will find several black dust covers. Twist off the dust cover closest to the fender (the outward dust cover) to access the turn signal bulb.
    4. Step 4 Turn the bulb module counterclockwise to release it. Unplug the electrical connector from the bulb module. Connect the new bulb to the electrical connector (don't touch the glass with your hands; hold it by the plastic piece). Insert the bulb module in the turn signal housing, turn it clockwise and screw the dust cover back on.
    5. Step 5 Insert the headlight case in the mount. Push the pins back down to secure it. Position the radiator baffle in its place and insert the fasteners.
    6. Rear Turn Signal Bulbs
    7. Step 1 Open the trunk. Remove the net from the side mounted wing nut (on the side with the faulty turn signal). Twist the wing nuts (there are two per side) counterclockwise to remove them.
    8. Step 2 Peel the carpet layer back to access the rear signal lamp wing nuts. Twist these wing nuts (two per side) counterclockwise to remove them and release the rear signal.
    9. Step 3 Carefully pull the rear signal assembly away from the Impala. The rear turn signal is the inner bulb (closest to the trunk). Press the tab on the bulb module and turn it counterclockwise to release it from the rear signal assembly.
    10. Step 4 Pull the old bulb straight off the module (don't twist). Insert the new bulb in the module. Depress the tab on the connection and insert the module back in the assembly. Twist it clockwise.
    11. Step 5 Insert the rear signal assembly. Re-attach the assembly's wing nuts and push the carpet layer back in place. Tighten the other two wing nuts to secure the carpet layer and reconnect the cargo net
    May 09, 2010 | 2003 Chevrolet Impala
    How do you replace the drivers side headlight bulb on a 2004 New Beetle convertible?
    1. Remove headlight housing. A.Open Hood and pull the release lever at the back of the housing. The headlight housing slides in and out of the body in tracks. B.Pull out the headlight housing far enough to disconnect the electric connectors, then slide the housing completely out. 2. Remove the retaining clip to remove the upper (low beam) or lower (high beam) bulb from the holder from the back of the housing unit. Remove the old bulb(s). 3. Do not touch the bulb with your bare hands! Wear clean gloves or hold with a clean paper towel. Fingerprints on the bulb will cause the bulb to burn out or explode!. Insert the new bulb. 4. Replace the retaining clips and insert the housing back into the tracks and into the body. Plug the electric connectors in and insert the housing completely. 5. Reposition the release lever to the original position being careful not to break the plasic lever. 6. Check your lights for operation.
    Nov 01, 2009 | 2004 Volkswagen Passat
    Changing the headlight bulb in 2003 dodge grand caravan
    1) open the hood.
    2) Carefully remove the three screws holding the headlight assembly in place.
    3) Carefully slide the headlight assembly out. At this point you can replace the headlight bulb, turn signal bulb, or the entire headlight assembly. To replace the headlight bulb turn the collar holding the bulb in counter clockwise. Pull the bulb out of the headlight assembly. Replace the bulb. Insert the bulb into the headlight assembly insert the collar and turn clockwise until it locks. (Do not touchglass with your fingers or it will cause the bulbs to catastrophically fail - clean with alcohol pad if you touch the glass)
    4) Carefully insert the headlight assembly back into place.
    5) Replace the three screws removed in step 2 being careful not to over tighten.
    Oct 30, 2009 | 2003 Dodge Grand Caravan AWD
    InFocus LP 130 Multimedia Projector Logo
    74 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
