Question about Omega Iwatsu ZT-24KTS-SP Speakerphone - GREY
I dropped my Iwatsu adix 24 button phone on the floor and now the display is not working. Everything else, lights, dial tone and handset are working.
Handset on Mitel 5340 IP phone with bluetooth has no dial tone but has dial tone on speaker. Bluetooth signal is fine. Help.
Are you referring to the Mitel Cordless handset or headset? The handset and headset must be paired to the module on the back of the phone. Press and hold the button until the display indicates pairing. Then press the Answer button on the handset or headset.
Jan 07, 2011 | Mitel 5340 IP Phone
Handset displays "Line in Use" no dialing tone and
I can't get dial tone either. Let me know if you find a solution please.
Dec 12, 2010 | Siemens Gigaset 4015 Cordless Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Replaced battery in handset. Got a dial tone and all was well. Picked up handset later in the day and it was dead. Unplugged and reattached everything - no luck.
Try taking batteries out, but also unplug base station. The aim is to disperse all power in the phone so that it resets itself. I would leave everything unplugged for 24 hours and then reassemble and see if the problem has gone. Its worked for me loads of times with different electrical appliances. Hope that helps.
Apr 23, 2009 | Sony SPP A1050 Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
Jul 19, 2008 | GE 25942GE2 Cordless Phone System
Disfunctional Handset
has the secondary handset ever worked. Reason I ask is that it happened to me with a new addtl handset and the problem was that I did not remove the small piece of paper between the handset and the battery which caused only distorted figures to display on the LCD of the handset.
Nov 22, 2007 | Vtech VT 2461 Cordless Phone
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Omega Iwatsu ZT-24KTS-SP Speakerphone - GREY Logo
111 people viewed this question
Top Omega Lands Phones Experts
David Burbee
David Burbee
Are you an Omega Lands Phone Expert? Answer questions, earn points and help others
