No because it is too dangerous. When you go into Airplane Mode, you literally turn everything off! Airplane Mode is only for being on an airplane. If you are using it a lot whilst not flying, you are not using it correctly.
Pene; Are you talking about a mobility scooter, please RE POST if you are, with more information approx year, make, model # and detailed description of problem.
Did you check if batteries got exhausted? Else, if you flew it 3 times and afterward it stoped responding,I would say that you are not doing anything wrong. The problem is your flying gadget. It it's on warranty, return it
That's what airplane mode is designed to do. Airplane mode turns off cellular and WiFi connections on your phone, laptop, or tablet when you're flying. This rule is in the process of being changed, but as I write this, it's illegal to use such connections on commercial flights.
Airplane Mode (Motorola CLIQâ„¢ with MOTOBLURâ„¢) NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active. To turn Airplane mode on or off, refer to the following: ---------------------------------------
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps: 1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps: 1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
i have the same game but for a different console, the farther and higher you jump, the farther the hawk will carry you, and for the hawk to fly approximately 1/2 a second after you jump, that's what worked for me, though it still takes about a couple tries
I'd recommend the this one: http://www.bhphotovideo.com/c/product/162616-GREY/Canon_2577A002AA_100_400mm_f_4_5_5_6L_IS_USM.html At a 1.6x multiplier, that gives you an effective length of 640mm along with Image Stabilization.
